Home > Technical (L322) > 4.4 TDV8 no start no crank |
PeterRRVogue Member Since: 22 Jan 2022 Location: Brackley Posts: 72 |
Hi guys, so I managed to do as suggested and here are the results:
20th Apr 2022 12:34pm |
I also connected a tightly fitted tube to the oil suction pipe (see foto) and tried to blow in. The bad news is that I could fairly easily blow the air in (hearing oil bubbling in the engine). I could not see any oil escaping from the side of the engine (the engine has 9.5l of fresh engine oil) but if I understand this correctly, I shouldn't be able to blow the air into the engine unless there is a hole in the block?
20th Apr 2022 12:39pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2314 |
The engine has a breather that vents to the inlet tract.
20th Apr 2022 1:15pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
well, it turns over! maybe you don't have high current passing through the connections, and its as sluggish as the video suggests. guess its still easy to reconnect the original cables, and try again, and maybe with a different battery, (the second battery?) and see if it cranks faster? i wouldn't worry about looking for a holed block, as that is a typical thing of a terminally ruined engine, (normally if a con-rod bearing starts to run dry, and start 'knocking' and then lets go from the crankshaft, it get hit by the crankshaft on the next revolution, and is smashed through the block... its still possible, but you might be seeing oil getting thrown out that hole by now, with the slow cranking... i would stick to getting good cleaned connections to the starter, and battery terminals, and seeing if it will crank faster. if you can get it cranking, but not 'firing' that can be a multitude of different things, but the way to prove it 'can fire up' is to spray some Easy Start (halfords) into the plenum, via the air filter pipe(s) pop one off, and give it 5 seconds or spray into the engine) -if you get a slight fire up, then you are missing fuel, ie fuel pressure.... and the easy start is firing up, and trying to start etc. it needs to be pinning over faster firstly though. keep the details coming! -can we get longer videos?? |
20th Apr 2022 1:25pm |
Thanks GraemeS! So that means that being able to blow air into the oil suction pipe doesn't mean that a piston punched a hole through the block..? Also I tested the positive battery cable at the starter motor once again (just to be sure) and I definitely get no 12v there which means the cable has definitely a fault. Could my issue by purely caused by a faulty alternator (dead shot) and battery cable or the hesitant engine spin also suggests a mechanical engine issue? |
20th Apr 2022 1:26pm |
Thanks Johnboyairey! I guess before I reconnect the original cable, I first need to fix the main battery cable issue at the starter motor as currently there is no constant 12V going to the SM though the original cable. Also I suspect that the alternator might be faulty causing dead short as I keep getting 'low battery" warning despite that the fact that the main battery is brand new and constantly on a trickle charger. It doesn't seem like removing the alternator is an easy job just to test this theory though I will probably just order a new alternator and try to fix the main battery cable and then try to start the normal way and see if it spins! Sounds like a lot of work just to do a test, so if anyone has a suggestion on how to disconnect the alternator without going into all that effort, I'm all ears Also I will take more and longer videos to keep you guys posted! |
20th Apr 2022 1:40pm |
its possible to buy thick battery cables online.. so you can make up a cable, and run it direct, (with caution near exhaust etc) and bridge to connection with a known good cable. seems strange its not passing power, and i mean, 'no 12v' as you say....lack of high amp current is one thing, but no 12volts is like fully disconnected..sounds like the mega-fuse???? |
20th Apr 2022 1:48pm |
I get what you saying, but that's exactly what I find very strange too! I tested and cleaned both MEGA fuses and they look fine. But will do more checks and come back! |
20th Apr 2022 1:55pm |
there are some threads on here regarding the starter motor trigger wire, on the 4.4 tdv8... i have this issue, and changed starter motor twice now.... but yours has a slight different issue, in that the main cable is faulty, and not the trigger (thinner) cable. cables can go high resistance, through overheat, oxidation, even theives can reach under to cut cables to disconnect battery etc for alarms etc. im sure you will get your moment of bliss when the problem is revealed.... and you inform us its running! |
20th Apr 2022 2:39pm |
If you disconnect the mega-fuse, is there a huge spark when reconnecting it with the battery connected? I suspect not as you would have mentioned it but no huge spark indicates that the alternator isn't causing a dead short. Terminals are crimped onto cables which can work loose if the cables can move near the terminals which then become high resistance joints.
20th Apr 2022 10:10pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2705 |
Sounds like a weak battery on that video. 2012 TDV8 Vogue (L322) |
21st Apr 2022 9:50am |
Alright guys, so I made a breakthrough with the 'no power to the starter' issue. And I have to say that I feel like a proper moron now! Anyways, the whole time when it was referred to MEGA fuses, I always assumed that the only MEGA fuses there were, were the couple on the firewall behind the battery. However when I looked at the direction of the positive (red) battery cables, I realised the those two (250A) MEGA fuses at the back weren't powering the starter and I assume neither the alternator. So I had the light bulb moment to open the black plastic box directly connected to the positive battery terminal and what did I find there...? Another MEGA fuse, and this time it was the 400A one! This one turned out to be a complete toast as I couldn't get any continuity on it at all. Now I wonder what would cause this MEGA fuse to blow? Could it be a dead short on the alternator as suggested by Baltic Blue? or something else? Anyways, a brand new DENSO alternator is already on the way so now I need to find and order a new 400A MEGA fuse.
21st Apr 2022 10:54am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2984 |
I’ve been following this with interest. I don’t think I’ve ever seen or heard of one of those fuses blown.
21st Apr 2022 11:16am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3682 |
So that’s what a 400A Megafuse looks like. , we are all going to learn a lot from your pictures and work.
21st Apr 2022 12:07pm |
