Home > Technical (L322) > 4.4 TDV8 no start no crank
Page 3 of 12 <123 4 ... 101112>
Merchy
once you have fitted the new parts you will obviously get a clearer picture, hopefully it is not as dhallworth has suggested, but definitely a possible cause.
Another possibility is that the following could have occurred, high capacity HRC ( High rupture capacity ) fuses in my line of can fail for no apparent reason, very rare, but it can happen especially with age. Also, another possibility is that if the connecting wire has been forced at some time in the past and cracked at the terminal end part where it has failed, the crack would then induce overheating in that area, leading to failure as seen in the photo. Wires / connections can get more brittle with age and use and be more prone to cracking. best outcome would be if it was a one in a million failure due to materials.
I am not saying this is a definitive answer, just thinking about various possible causes, hope all goes well Sir. Thumbs Up
Post #629301 21st Apr 2022 12:20pm
PeterRRVogue
Thanks guys! it would be great if replacing the 400A MEGA fuse and putting in a new alternator was all that's wrong with the car (excluding the oil leak from the top oil cooler and a few O rings that I had already fixed), but I am not that lucky Shocked so I am fully expecting more issues to re-surface once this has been fixed. At least, I feel like I'm making some sort of progress Laughing
Post #629302 21st Apr 2022 12:36pm
kevinp
Just done my alternator and my top tip is to pull the power steering reservoir out it's bracket and lay it down where the removed air filter was, and unbolt the bracket. Takes about a minute of your time but makes it so much easier to remove the fan shroud. Thumbs Up
Post #629309 21st Apr 2022 2:08pm
johnboyairey
sounds like some decent progress. to change the alternator, is a bit of a pig of a job, but there's a recent YouTube, from 'Sams motor and machine' channel showing the changeout.... -but, you could just bypass the alternator, by disconnecting it... and insulating the connections... and put a fuse in, and get some power onto the starter.... you can come back to the alternator, once you know its worth changing. fuse could have been bent, and then cracked, and then burnt away on the crack etc...
the suspense... its great!
Post #629322 21st Apr 2022 6:00pm
PeterRRVogue
Thanks for the tip Kevinp. I could see that the power steering reservoir is in the way so definitely will follow your advice!
Post #629323 21st Apr 2022 6:22pm
PeterRRVogue
Thanks Johnboyairey! I started following Sam's channel before I decided to buy my RRV Smile and indeed saw the video on the alternator change which is very helpful. You have a point about bypassing the alternator, but since in order to disconnected it, i need to remove the old one (unless I'm missing something which is entirely possible given my recent history Laughing ) and also given that the new one will be arriving tomorrow, I might as well just swap it and at least be able to eliminate the alternator issue. As my RR has currently 136k miles, so even if the old alternator is still ok, it's only a question of time before it needs replacing so I might as well just do it now.
Post #629324 21st Apr 2022 6:31pm
johnboyairey
you've got a little bit of catching up, to my 2012 Westminster, at 200,000 miles.
Post #629325 21st Apr 2022 6:59pm
PeterRRVogue
Hope my engine is capable of covering an additional 2 miles without a full re-build Confused
Post #629327 21st Apr 2022 7:10pm
johnboyairey
I can't comment on the low oil level without more info, but the likelihood of the engine being toast, AND the mega fuse going pop, with an engine that can still turn over, is slim..... I think the messy oil on the engine, was a bumsteer, the fuse was the culprit, probably damaged by battery fumbling....and you just need to get the thing spinning, and see what happens.
the best of luck fella.
Post #629329 21st Apr 2022 7:36pm
GraemeS
Australia
Was the fuse blown or just high resistance at the bolts due to corrosion?
Post #629340 21st Apr 2022 9:46pm
PeterRRVogue
It's a blown fuse. I couldn't get any continuity between the two ends even after a good clean with a sand paper
Post #629392 22nd Apr 2022 1:33pm
PeterRRVogue
I really do hope you're right Johnboyairey!
On a positive note, the new alternator arrived earlier today so I'll have a go at swapping it first thing tomorrow. I also ordered a brand new 400A MEGA fuse (genuine Land Rover) so hopefully it arrives early next week so we can test what happens Bow down
Post #629395 22nd Apr 2022 1:38pm
PeterRRVogue
Just a quick update on my progress. Today I had a go at swapping the alternator and I can confirm that getting to it was a real pain Neutral I am attaching a few photos below in case someone finds them useful. There were three main observations from the process.
1) when disconnected the turbo actuator from the radiator, a lot of (fresh) looking oil poured out of the hose/radiator. My guess is between 200-400ml. I was expecting some amount of oil, but nowhere near as much and also the fact that it looked very clean (nothing like the sludgy mess the car arrived with) left me a bit puzzled. I did fill the engine with fresh oil about a week ago but I haven't run it yet so not sure how would the new oil get there? Could it be a blown turbo?
2) After I removed the old alternator, I tested the continuity between the positive terminal and the body (ground) hoping to discover dead short which might explain the blown MEGA fuse, but that didn't happen. The alternator didn't seem to have a dead short, so it rules it out as the cause of the blown fuse Crying or Very sad I also noticed that on the sticker of the old alternator it says 12v while the new one is 14v. Does anyone know if this is a potential issue? Should have I gotten a 12v version instead?
3) as I had to remove the fan cowl and all the pipes which were originally in the way of trying to hand spin the engine through the crank bolt, I finally could try hand spinning it and I can confirm that the engine spins. I don't have much experience trying to hand spin big v8's but it wasn't exactly effortless so I'm not sure whether the engine is too tight or it's just a normal resistance that ought to be expected. I guess I will find out soon Confused
The MEGA fuse should arrive on Tuesday is will let you guys know as soon as I fit it in Wink
Post #629551 23rd Apr 2022 9:54pm
kevinp
Your new alternator box has the same info on it that mine had.
Diesel engines have a lot more compression than petrol engines so will be quite hard to turn over.
Your COSV valve has the old style nut attachment. There is a revised part for this. Put a vacuum on the hose and make sure it opens fully and closes with a clunk.
Good luck.
Post #629592 24th Apr 2022 12:13pm
johnboyairey
I had my turbo actuator valve off when I took the cowl off to do my water pump. I got about a tablespoon of oil all over me. It was typically black though. I guess whatever makes it’s way down there, is never going to come through to the engine, so will pool. My engine has 200,000.
Is there a chance, that your new oil going in, flooded the upper engine valve area, and overspill into a breather and dropped down to pool at the turbo actuator valve? If it was there for some time, then it would go dirty-ish to some extent with fine dust…
May I ask how much one of those mega fuses cost, as it’s something I might just keep as an emergency type thing.
Post #629627 24th Apr 2022 8:56pm
