Home > Technical (L405) > Slight clonk from drivetrain on downshift - normal ? |
lambo911 Member Since: 13 Jan 2022 Location: St Albans Posts: 72 |
I am assuming it has the latest software as it was sold by a main dealer last May and it had a winter check and system check in December.
4th Apr 2022 3:07pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1341 |
The gearbox software fix is not one of the routine software updates, it is a bulletin item which the dealer said is only done if the car has problems, specifically thudding on kickdown, so it is probably not safe to assume that it has been done in the past. I'd ask the dealer about the bulletin specifically (it may be the dealer can find out from the service records whether it has been done) and if they don't know about the bulletin ask them to speak to LR about it.
4th Apr 2022 3:26pm |
I wonder if it is this bulletin https://www.tsbsearch.com/Land-Rover/SSM73409 2016 AB SDV8 Barolo black |
4th Apr 2022 4:19pm |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 219 |
Does anyone know if the software update can be installed using the Gap IID Tool? Dan. 🇨🇦 2013 L405 5.0 SCV8 |
4th Apr 2022 5:57pm |
So I spoke to the warranty company and asked if an oil change would be covered as it is not a service item and they thought it would but the dealer would need to make a warranty claim.
6th Apr 2022 2:46pm |
I contacted Gap and purchased Fast Lane Service for the Transmission and Transfer Case ECU software updates. I installed them yesterday. Worked like a charm! The clunk is gone. Perfect for $84 🇨🇦. I should have tried this first before replacing components and oils (which needed replacing anyway). Dan. 🇨🇦 2013 L405 5.0 SCV8 |
8th Apr 2022 3:30pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 735 |
Great news
8th Apr 2022 4:22pm |
No I did not this time. The flash takes five minutes. The vehicle starts/stops several times on its own during calibration of the transfer case sensor and clutches.
8th Apr 2022 4:30pm |
The car went into to LR today for an oil change, gearbox reset and latest software all done under warranty. I have only done a short low speed journey so I am not sure if the clunking issue is fixed yet but will keep you posted.
26th Apr 2022 5:37pm |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 240 |
it is very bad you would think that for the money they ask everything would be done right |
28th Apr 2022 1:03pm |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 442 |
I can’t believe they wouldn’t do a road test after completing a job such as this, its basic good practice IMO, and gives you confidence they actually care! |
29th Apr 2022 10:00am |
Hi All, I did a few hundred miles over the weekend and the oil change has certainly smoothed out the gear changes so well worth doing.
3rd May 2022 10:10am |
MrWold Member Since: 26 Feb 2022 Location: West Sussex Posts: 132 |
As a newbie I've kept quiet but if no-one else is going to answer...
4th May 2022 12:56pm |
I would not go as far as to say a clonk but you can hear it engage and feel it take the play up in the drivetrain which is normal especially when they get a bit of mileage on them.
4th May 2022 1:18pm |
