Home > Technical (L322) > Knocking noise at front end
cabletastic
United Kingdom 2006 Range Rover Vogue Td6 Barolo Black
Greets all - newbie here. Bought my first L322 a week ago having normally worked on various Mercs. I have a knocking noise over speed bumps on the front passenger corner - have not had chance to get under it and wiggle things but thus far am guessing it to be an anti roll bar bushing (purely based on experience with a previous CLK), If it is this, anyone know how much of a pain this is to replace? I have found videos of L320s which seem really easy as the bushings are mounted vertically and quite easy to get to but I have also found several websites saying that to change them on an L322 it's a full subframe out job? Can't find a video link for a full fat, hence why I am asking here. Thank you in advance for any help.
Post #631279 11th May 2022 8:49am
Merchy
The engine sub-frame has to be lowered to change out the anti roll bar, but I have changed the bushes on mine on my drive way with the car on axle stands, not too bad a job. Whilst you are under the car it's worth checking the drop links, as they can produce the familiar knocking noise. Plus, with both drop links removed it is easier to change the roll bar bushes. Hope this helps Thumbs Up
Post #631282 11th May 2022 9:03am
cabletastic
Thank you mate. Was going to do the drop links as well as that’s a nice easy job. Might give these a wiggle first in that case if they could be the issue and save myself some work. Thanks again!
Post #631283 11th May 2022 9:06am
Bingo_123
a fellow member did ARB bushes recently, more info here in his thread, with lot of details.
https://www.fullfatrr.com/forum/topic61540-75.html
Post #631284 11th May 2022 9:29am
cass
I would change the drop links anyway, they're cheap, it's easy and I've found they can knock even when you can't detect any play.
Post #631288 11th May 2022 10:10am
cabletastic
Yep - have ordered a package with the two links and two bushings. Not looking forward to hacking it off, as per the link but hey ho!
Thanks for all the advice folks.
Post #631296 11th May 2022 11:07am
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Hey. It’s highly unlikely to be ARB bushes. Mine had done 143k and they were fine but I hacked them off anyway and changed them.
Knocking at front in order of likelihood is
Rear lower arm
Front Lower arm
Ball joint
Drop links
The suspension on these cars takes a pounding as it’s so heavy. Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #631330 11th May 2022 6:59pm
cabletastic
Thanks for the tip. Was guessing at drop links anyway (hoping actually as easiest fix!)
Post #631347 11th May 2022 9:14pm
Caesium
The previous owner of mine also thought the drop links were the culprit and changed them but I knew it was something else, I offered him less because of that.
Unless the lower arms have already been done then it will be them, especially the rear one as that has a lot more movement than the forward one.
The arms wear out before the drop links do, because of the type of load they are under. I changed everything.
DO NOT BUY BRITPART unless you like to repeat your work almost immediately after completing it. I had a britpart arm fail after about three months, seems they had forgot to grease the balljoint. Rolling with laughter
Check my project post and it's all on there. Christian.
Current Cars
2019 BMW X4
or
Post #631378 12th May 2022 8:44am
