![]() | Home > Technical (L322) > Knocking noise at front end |
| Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238
The engine sub-frame has to be lowered to change out the anti roll bar, but I have changed the bushes on mine on my drive way with the car on axle stands, not too bad a job. Whilst you are under the car it's worth checking the drop links, as they can produce the familiar knocking noise. Plus, with both drop links removed it is easier to change the roll bar bushes. Hope this helps |
| cabletastic Member Since: 10 May 2022 Location: Surrey Posts: 5
Thank you mate. Was going to do the drop links as well as that’s a nice easy job. Might give these a wiggle first in that case if they could be the issue and save myself some work. Thanks again! |
| Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 176
a fellow member did ARB bushes recently, more info here in his thread, with lot of details.
| cass Member Since: 12 Oct 2011 Location: northumberland Posts: 797
I would change the drop links anyway, they're cheap, it's easy and I've found they can knock even when you can't detect any play. |
Yep - have ordered a package with the two links and two bushings. Not looking forward to hacking it off, as per the link but hey ho!
| Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454
Hey. It’s highly unlikely to be ARB bushes. Mine had done 143k and they were fine but I hacked them off anyway and changed them.
Thanks for the tip. Was guessing at drop links anyway (hoping actually as easiest fix!) |
The previous owner of mine also thought the drop links were the culprit and changed them but I knew it was something else, I offered him less because of that.
| All times are GMT |
