![]() | Home > Technical (L322) > 4.4 TDV8 no start no crank |
Dave lincs Member Since: 31 Dec 2021 Location: louth Posts: 42 ![]() ![]() |
Dont want to sound stupid but are you sure the fuel in the tank is diesel, these days if mixed it can be difficult to tell i would take a sample of fuel from filter and test it for a presence of any petrol years ago had same problem with a rover 75 that nobody else could fix and sure enough it has mix of petrol with the diesel
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1416 ![]() ![]() |
Having seen the oil filter (never ever seen anything like that |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3327 ![]() ![]() ![]() |
I've just watched your cranking video's again.
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 173 ![]() ![]() ![]() |
From experience with the 3.6 which is a totally different engine, it would die with 60 miles range still showing. I used to put fuel in then have someone turn the ignition on whilst I held a Schrader valve in the fuel rail open with the tip of a screwdriver. When the fuel bled through it hit the open bonnet with some force. Then the car would start. I assume the 4.4 will have a similar duel fuel pumps arrangement as it has the saddle tanks. So look for a Schrader valve on the high pressure fuel rail.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2743 ![]() ![]() |
A starter motor will slow after cranking for several seconds due to the battery depleting, not necessarily slowing due to increasing compression but still possible especially if the exhaust is blocked.
SilverSpanner Member Since: 28 Jun 2017 Location: Hamilton, South Lanarkshire Posts: 17 ![]() ![]() ![]() |
According to the Owners Manual, there is fuel system inertia switch in the system that can be tripped. It says to seek assistance should it have been operated. 2012, FFRR Westminster TDV8 - Orkney Grey
See above 2012, FFRR Westminster TDV8 - Orkney Grey
PeterRRVogue Member Since: 22 Jan 2022 Location: Brackley Posts: 84 ![]() ![]() |
Sorry guys for the lack of updates as I was snowed under with work this week. Unfortunately I seem to be stuck on the 'no start / no crank' issue once again unable to resolve it. I get no IID fault codes, and all the engine compartment fuses seem to be fine (including all three MEGA fuses). I also manually checked the voltage at the starter motor and all seems to be in order. However when I press the starter button (with ignition on), it just restarts (see video below). I feel at complete loss now on what this could be as I believed that the original cause behind the no crank was the blown 400A MEGA fuse. Once this was replaced alongside the starter motor and the alternator, it was cranking for about three days days, until it wasn't for no apparent reason! Any ideas on what could be causing this would be greatly appreciated!
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3324 ![]() ![]() ![]() |
Maybe do a reset ? Disconnect the battery, wait 30mins (?) then touch the pos and neg leads together briefly and reconnect. 2012 TDV8 Vogue (L322) |
I had the battery disconnected since Monday afternoon until an hour ago. |
Have you checked the earth side of the battery? Engine earth strap etc? 2012, FFRR Westminster TDV8 - Orkney Grey
I've thoroughly checked the earth and I don't seem to have any issues there. I even connected a jump cable from the negative terminal on the battery to the engine without any difference in the behaviour. |
How is the positive terminal? |
Alright guys, so it's indeed most likely is a bad earth after all |
