![]() | Home > In Car Electronics (L322) > Best/easiest place to get ignition live in boot? |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 798 ![]() ![]() ![]() |
I'd have thought that the easiest is the cigar lighter socket in the boot....
It may or may not be relevant to a 2007 model but earlier cars had an ignition controlled cable as part of the feed to the trailer socket. The cable was 0.5mm and was green / yellow and could be found in the loom running above the rear fuse board position. If you find this cable and intend to use it to splice into bear in mind it can only be used to switch a relay for additional equipment, it’s fused at 5A. |
Seriouslthinkingaboutit Member Since: 12 Mar 2022 Location: Essex Posts: 98 ![]() ![]() ![]() |
You may be right JMC
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
Thanks - the cigar sockets in the car semi to be ignition lives but the boot one is permanent - can that be changed with relay did I once see?
I’m sure I read somewhere that in spite of manuals saying the rear cig lighter is permanent that it does switch off when car goes to sleep. Have you got anything with a light you can plug in and watch through the window?
I have a tyre compressor I could put the lead out the window - how long until it sleeps? Current stable:
Not sure. 10 mins rings a bell but others will know better.
You could put a USB adapter in and run a long phone lead out the window to see how long it stays on charge. Not sure how long a compressor will run with no load before overheat cutout. 2007 4.2SC Buckingham Blue
I’ll just turn it on and off every few mins Current stable:
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1582 ![]() ![]() |
There is one on the 2003 model - I use it to turn on the dual battery controller. Ron B. VK2OTC
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7966 ![]() ![]() ![]() |
The cig lighter stays on with the earlier cars. 2010 MY cars don’t, goes off when the car goes to sleep. I know, cos I have a 12v cooler box that won’t stay powered on 🤣. Did on my TD6.
Yea cig lighter in boot is not ignition although car ones are oddly …
