![]() | Home > Maintenance & Mods (L322) > TD6 Brakes. At loose end |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Is the length of the servo pushrod compatible with your servo?
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 ![]() ![]() ![]() |
The servo and Master cylinder were off a 2005 TD6 and came complete. So should be same as mine.
I don’t know about these cars but l seem to remember adjusting the push rod length on a discovery l had. Can’t remember why though.
Just been and checked (the servo I took off) doesn’t look like any adjustments.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7992 ![]() ![]() ![]() |
No expert, but do you have to put the ABS unit in to bleed mode to get all the air out?
If that’s a thing, then could well be?
https://workshop-manuals.com/landrover/l32..._bleeding/ 2011 Range Rover Vogue SE 4.4 TDV8
70.25.02
Thank you so much buddy.
No worries….
Cheers anyway fella.
According to the above procedure outlined as the master cylinder is upstream of the brake modulator you need to have the system bled using T4 diagnostics.
Thanks all for the input.
I’d just use the hill decent as a first try. No need for low range or wet grass…. Just need a road on a hill… activate it then accelerate and then remove your foot… car should keep to a bit more than walking pace despite the hill. You will hear the ABS clicking. 2011 Range Rover Vogue SE 4.4 TDV8
