Home > My Range Rover > Back with another Supercharged
Page 30 of 58 <123 ... 293031 ... 565758>
Sandyt
or a dream even freudian slip there
Post #631852 16th May 2022 4:31pm
dhallworth
That's the symptoms that my car was exhibiting when the rear diff was noisy.
If you need a transfer box, Rob at Duckworths sorted me out and it was fairly straight forward to fit Smile
Post #631853 16th May 2022 4:35pm
Sandyt
Yes remember seeing that in your earlier post probably is the diff might replace them both I have used GoS as you mentioned before for the p38 so might see what they have as the diffs are easy to swap out
Still no news from Atlantic ?
Post #631854 16th May 2022 4:38pm
dhallworth
I had a used transfer box from GoS but when you got up to motorway speeds the bearings in it really weren't happy. They were great in refunding me but it did mean that I had to strip it all again which was when I'd had enough and ordered a new one.
My rear diff was rebuilt by D&A Steering in Birmingham. It was 1/3rd of the cost of a recon one from LR and it's D&A that recon them for Land Rover so was worth a punt.
Nothing from them yet, I'll give them till around 8pm this evening and will give them another call.
Post #631855 16th May 2022 4:43pm
strongstuff
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
David,
Not sure how you got on with finding cams, but I've just spoken to my mate, ex LR Mastertech who is now an independent about where you'd maybe find such things and he suggested his engine builder (he races those Bowler thingies)
His suggestion was to speak to Roland at ACR.
https://www.automotivecomp.com
I really hope that helps! 2008 L322 4.2 V8 SC Stornoway Grey
2006 L322 4.2 V8 SC Java Black
Post #631864 16th May 2022 5:41pm
Sandyt
I will give the boys in D&A a call might replace both or have them rebuilt as think it will be a year before I buy an SV dynamic
Post #631865 16th May 2022 5:42pm
dhallworth
Just heard back from Atlantic British. They've got the camshaft and can ship it to the UK.
They're charging $200USD just for shipping which I thought was expensive until I tried to get quotes to ship it myself. Cheapest quote I got was $235 with a declared value of $50! Last time I tried shipping to the states it was nothing like that price!
Oh well, got no choice I suppose! 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #631876 16th May 2022 7:21pm
strongstuff
Have you seen my post above RE: Cams?
You never know, it might just help. 2008 L322 4.2 V8 SC Stornoway Grey
Post #631877 16th May 2022 7:23pm
Sandyt
That is nuts pity Mel has retired otherwise she could pick them up I dont know anyone anymore in the airfreight business so cant help
Post #631878 16th May 2022 7:31pm
dhallworth
StrongStuff - I hadn’t, I must’ve scrolled past that one. I’ll give them a call tomorrow Smile Thank you.
I agree, Sandy… it’s a huge amount of money for shipping something that’s pretty small really! 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #631879 16th May 2022 7:37pm
strongstuff
No worries, he just text me to say to try here too.
https://nwsmotorservices.com/engine-models...and-rover/
Aaron 2008 L322 4.2 V8 SC Stornoway Grey
Post #631880 16th May 2022 7:42pm
dhallworth
Thanks Smile
Have emailed both of them. Will see what they say before going any further with Atlantic British.
Post #631881 16th May 2022 7:46pm
Seriouslthinkingaboutit
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
It’s a thought - is there anyone out there who modifies these engines RR or Jag for motorsport or Restomods. I found the cheapest new injectors I could get for my son’s Fiesta ST a while back was from Caterham as they strip them out for their 7 engines.
Douglas 2007 4.2SC Buckingham Blue
https://www.fullfatrr.com/forum/topic63319.html
Post #631884 16th May 2022 8:03pm
dhallworth
I’ve not found anything along those lines when Googling unfortunately.
The cams are also unique to the Land Rovers, the Jaguars use different cams.
If I don’t hear anything from the 2 places above I’ll order the one from the US as I really want this car back together ASAP now.
Post #631887 16th May 2022 8:08pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
dhallworth wrote:
That's right.
I've got most things from Bilt Hamber.
Deox C - Mix it with water, submerse things and the rust is treated whilst submersed.
Deox Gel - Plaster it on thick with a brush, cover things in clingfilm and wash off with soapy water.
Hydrate 80 - Paint on metal once you've removed the loose rust and it cures the rust.
Zinc Corrosion Paint - Spray onto the rust treated surfaces. (Screwfix)
Epoxy Mastic - Mix the tin incredibly well, I used a bent wire in the drill, add the hardener and mix again, then paint on.
On the subframe and wishbones I applied the epoxy direct to bare metal as they'd been blasted. On the underside of the car I used the zinc paint before applying the mastic.
Until starting this I was very much in the same boat as you. This is the first thing I've really spent any time on doing rust work.
Thankfully, none of our P38's have had anything more then surface rust so I've never had to do similar works to them.
David.
Hi David
Could you let us all know how much of each product you needed to complete your project, it would help me/us decide what is needed for smaller projects.
Also I was planning to just use Hydrate 80, and Zinc and then a top coat (maybe after what you have said using Mastic), so could you explain when or why you used the Deox products.
Many thanks
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #632197 19th May 2022 12:37am
