Home > Technical (L405) > I'm now a Regeneration trainee nerd--lol
Page 3 of 34 <123 4 ... 323334>
Kot
I use RRS V8 4.4 (EN) 2018 SE SDV8 4.4 Byron Blue
Post #632336 20th May 2022 11:58am
Gremlin500
@MarkA,
You don't use any vehicle bluetooth profile, if I understand you correctly.
The Vgate iCar Pro BLE 4.0 connects directly to the Car Scanner Pro app in your phone via Bluetooth 4.0 (needs a newish phone)
Clear instructions are given with the Vgate unit. it's neccessary to select the correct vehicle type in the app, you can use "Demo" mode for this, and the app will remember all settings when you make the real connection.
Hope this helps.
EDIT: One more thing, be careful about which Vgate unit you buy, there are a LOT of the old ones on the net.
I think mine was £27 on Amazon IIRC. V6 Vogue - “Less is More” - less to go wrong!
Post #632339 20th May 2022 12:37pm
MarkA
United Kingdom 2014 Range Rover Vogue SE SDV8 Causeway Grey
I bought the gate from Amazon so should be ok, it’s the connection profile within the app that I wasn’t clear on and using the basic land rover connection didn’t see all the sensors.
Will update to the 4.4 one and review my outputs tonight.
Thanks both
Post #632345 20th May 2022 1:37pm
Kot
I actually have the wifi vgate, the app works with both wifi or BT Vgates.
The wifi address comes up as VLink, also noticed that now and then it is not discoverable so unplug vgate momentarily and reinsert solves that.
I choose wifi just to be different lol as I already had a BT AP200 which I use on DTC etc
Agree use Amazon as a few Chinese copies that dont work are circulating, at least with amazon you can return it easily enough. 2018 SE SDV8 4.4 Byron Blue
Post #632346 20th May 2022 1:41pm
Bill
ajac8 wrote:
Lost me there chaps.
I'm a surveyor not an engineer - I like mine cuz its Blue. Laughing
Rolling with laughter Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #632348 20th May 2022 2:03pm
Bill
Re: I'm now a Regeneration trainee nerd--lol
Kot wrote:
So being a retired Engineer, I couldn't let it rest.
Why JLR, for the sake of another lite on the dash!
Pleased you didn’t let it rest, very informative. I’m not ajac, I’m not a surveyor, but I like my colour as well .
Does anyone know if the new 460 has the missing regen light … would be handy Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
Post #632349 20th May 2022 2:09pm
Bill
Gremlin500 wrote:
@Kot: and fantastic value at under £35 Thumbs Up
So…. With all this info available , why doesn’t JLR put it on display. I wouldn’t use it 99 percent of the time , but for my £ 125,000. I would like to decide if I want to use it or not. With this new super screen on the 460, will this info be more easily displayed using a widget interface thingy ( technical term) ? Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
Post #632350 20th May 2022 2:24pm
Kot
Bill
It would be easy for JLR to put this info on the screen after all the vgate is getting this information from the Bus through the obd port.
But someone somewhere in JLR doesn't want joe public to see all the available parameters.
Regarding the 460 and later 405 they use D300/D350 engines there was some talk on here that fuel dilution issue has been controlled by the dpf being moved to a different position. 2018 SE SDV8 4.4 Byron Blue
Post #632362 20th May 2022 5:02pm
Bill
Thankyou Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
Post #632367 20th May 2022 5:39pm
MarkA
Thanks both
Mines going back, it makes my instruments flash stop working!!
Post #632368 20th May 2022 6:04pm
Kot
MarkA
What is your MY? 2018 SE SDV8 4.4 Byron Blue
Post #632377 20th May 2022 7:08pm
MarkA
It’s a 2014
Post #632381 20th May 2022 7:32pm
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
Hello
So I set this up on my car.
So the trigger is at 92/93% so I assume that a Regen will happen soon. At the moment the Km until next service is climbing.
So during a short drive I saw that a passive Regen happen for a minute.
So I had a new DPF fitted under warranty but I don’t think it has made a difference. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #632565 22nd May 2022 5:28pm
Kot
MarkA wrote:
It’s a 2014
MarkA
Is it a 3.0 V6? as a member in the RRS group had the same issues as you and stopped using it as it was not compatible. Is it OK if you use the basic obd II profile?
I also wonder if the can bus is different on the older models (pre2016) as it is known that GAP tool doesn't support 2016+ L405 for same reason. 2018 SE SDV8 4.4 Byron Blue
Post #632582 22nd May 2022 8:47pm
Gremlin500
Hi Kot, FYI:
Mine’s a TDV6 MY 2017, no issues with the hardware or software. Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #632589 22nd May 2022 9:07pm
