![]() | Home > Technical (L322) > Restricted Performance Fault TDV8 4.4 - 1750 rpm on Motorway |
Dave lincs Member Since: 31 Dec 2021 Location: louth Posts: 42 ![]() ![]() |
Same here as well |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7991 ![]() ![]() ![]() |
I wonder if having the cruise on alters what gear it might be in, or will drop early on an incline where you wouldn’t normally?
And the 3.6 would be in 6th….
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3325 ![]() ![]() ![]() |
The OP said ‘top’. Also no paddles on the 3.6 unless they have been added as a modification. 2012 TDV8 Vogue (L322) |
Ah, apologies. Not read it all. Trouble when replying when at work 🤣.
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 265 ![]() ![]() ![]() |
Suspect you guys are heading down the wrong road.
OK thanks for the clarification but 1600rpm still seems high for that speed - can you confirm you are running stock 255/50 tyres on your 20" wheels? Listening to the sound of your engine in the other thread I'd be looking at this as a priority for a restricted performance warning possible cause. 2012 TDV8 Vogue (L322) |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Have you had a look at the 4 rubber hoses that go into the Intake Plenum, the large plastic 'donut' that sits underneath the big plastic engine cover. It's possible you have a minor split on one or more of the hoses that is allowing a little bit of air to escape from the intake, causing higher revs due to loss of turbo boost.
Loss of turbo boost won't change the revs vs road speed ratio as these are mechanically locked (assuming the TC is not slipping) 2012 TDV8 Vogue (L322) |
The noisy engine is a different vehicle. Nothing has changed tyre wise for quite a few months. |
After a period where I wasn't getting any error codes I'm now getting the usual set, i.e. manifold absolute pressure and turbocharger boost pressure low. |
