![]() | Home > My Range Rover > Whats my Value? 2010 L322 4.4TDV8 Autobiography |
RichardHL3222010 Member Since: 26 May 2022 Location: Lanark Posts: 10 ![]() ![]() ![]() |
Just back from overhaul for the following by independent approved land rover specialist; 2 New genuine Garret Turbos includes warranty, 2 New Genuine Inlet Manifolds,2 New front Callipers Brembo high performance, New inlet and exhaust manifold gaskets New Oil feed pipes, New front Suspension Arms, New front ball joints, New anti roll bar links, Front subframe has been shot blast, galvanised, rust protection and painted, Inner and outer chassis Rails have been wire brushed rust protected, painted and waxed, Underneath car has been rust treated and painted back to fuel tank, New engine mounts, New front mud flaps, New heater resister, New ABS Sensors, New front CV Joints, DPF flushed and cleaned, New DPF pressure Sensor, loads of new screws, studs, seals, gaskets etc all listed with paperwork,
quavey Member Since: 22 Jan 2017 Location: Lancaster Posts: 323 ![]() ![]() ![]() |
L322's seem like all cars to be at an artificial high at the moment and with deliveries of the L460 starting it will depress L405's and likewise the L322's will suffer. If someone will offer you 15k for a 12 year old diesel 120k mile car I would be inclined to take it personally. I fear they have a long way to fall! Especially with global events, fuel prices and inflation etc
Thanks fella
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3329 ![]() ![]() ![]() |
Why did it need new turbo's at that mileage? 2012 TDV8 Vogue (L322) |
Car went into restricted performance randomly one day and that was it
Chrali Member Since: 13 Apr 2017 Location: Norwich Posts: 122 ![]() ![]() ![]() |
That must have cost an absolutely |
Yes it did! And I am
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3328 ![]() ![]() ![]() |
That’s some amount of work you’ve had done!
I am indeed just outside Lanark but my friend is in Leicester
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 406 ![]() ![]() ![]() |
I would be inclined to keep it after spending all that money on it - it's worth more to you than someone will be willing to pay I feel. Gavin
Agree it makes little sense to sell if you have sunk that much money into it. I’d be a bit concerned about the turbo fail as it would suggest prior issues with oil supply which may have consequences elsewhere in the engine as these very rarely fail on these engines. 2012 TDV8 Vogue (L322) |
