Home > My Range Rover > Whats my Value? 2010 L322 4.4TDV8 Autobiography
RichardHL3222010
United Kingdom 2010 Range Rover Autobiography 4.4 V8 Galway Green
Hi all
I have just spent a lot of money on my L322 and I am swithering on selling it or not. I am undecided but what do you recon the current value is? interested as they go from £15000-£20000 online with similar age and miles - although I have just done mega work to mine and cant find another one with the same history??
Here is the details
2010 Nov L322 Autobiography 4.4 TDV8
third owner (I bought it in 2020)
Galway Green with original autobiography alloys
good level of history
121,000 miles
12 months MOT - no advisories
Just had full service
Everything works as it should
V5, private reg, one key and service history all included
I am unsure whether I want to sell it or not but I am curious to what people would be willing to pay for such a beautiful example, and well maintained car. If its needed anything it has had it but like all LR once you fix one thing the next one comes up
This post has been edited by the site administration team
Post #632949 26th May 2022 2:04pm
RichardHL3222010
Overhaul
Just back from overhaul for the following by independent approved land rover specialist; 2 New genuine Garret Turbos includes warranty, 2 New Genuine Inlet Manifolds,2 New front Callipers Brembo high performance, New inlet and exhaust manifold gaskets New Oil feed pipes, New front Suspension Arms, New front ball joints, New anti roll bar links, Front subframe has been shot blast, galvanised, rust protection and painted, Inner and outer chassis Rails have been wire brushed rust protected, painted and waxed, Underneath car has been rust treated and painted back to fuel tank, New engine mounts, New front mud flaps, New heater resister, New ABS Sensors, New front CV Joints, DPF flushed and cleaned, New DPF pressure Sensor, loads of new screws, studs, seals, gaskets etc all listed with paperwork,
Included is a trickle charger and quick connectors fitted to battery, paintwork is beautiful with just a little scuff here or there.
Not so good points; Front Wheel bearings are sounding a little and getting old. intermittent screech from air fan blower. rear suspension arms need replaced as they creak when going over bumps, rear subframe could do with the same stripping and galvanising as I have done to the front - not immediate but in the next 18 months
Post #632960 26th May 2022 4:13pm
quavey
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Corris Grey
L322's seem like all cars to be at an artificial high at the moment and with deliveries of the L460 starting it will depress L405's and likewise the L322's will suffer. If someone will offer you 15k for a 12 year old diesel 120k mile car I would be inclined to take it personally. I fear they have a long way to fall! Especially with global events, fuel prices and inflation etc
However if you've spent all that one it you might as well keep it forever. 2005 E60 M5
2017 L405 5.0 AB
2024 i7 xDrive60
2006 (MY07) L322 4.2 S/C, 2004 L322 4.4 Vogue, 2002 L322 4.4 HSE, 2006 (MY07) L322 S/C , 2001 P38 Vogue, 1999 P38 4.6 HSE.
Post #632964 26th May 2022 5:54pm
RichardHL3222010
Thanks fella
Just stuck on what to do at the moment
I absolutely love the car but it has been expensive and there will probably be more to do at some point
Post #632967 26th May 2022 6:08pm
JayGee
Why did it need new turbo's at that mileage? 2012 TDV8 Vogue (L322)
Post #632981 26th May 2022 7:12pm
RichardHL3222010
Car went into restricted performance randomly one day and that was it
Upon inspection there was oil in the air filter and all around the wheel arch so the little
Turbo on the near side had given in
Once the engine was out the larger turbo on os was starting to leak oil too
Post #633002 26th May 2022 9:41pm
Chrali
That must have cost an absolutely Censored fortune and you're not going to see it back, so if can you should just keep it.
I can't imagine anything else you have to replace will cost anything like as much. Encourage alternative fuels, use all the petrol!
2012 Range Rover Vogue 4.4 TDV8
2006 Mercedes GL420 CDI
2006 Porsche Cayenne Turbo S
2006 Jeep Commander 3.0 CDI with GDE HOT Tune
1997 Nissan Patrol 4.2 GRSE
1995 Vauxhall Monterey Diamond 3.2 v6
1994 Range Rover 4.2 LSE Beluga Black, Softdash, Brooklands Body Kit - Loved it!
1993 Range Rover 4.2 LSE ended up converted to 300tdi
Post #633011 26th May 2022 10:54pm
RichardHL3222010
Yes it did! And I am
Inclined to agree I must have broken the back of the mostly costly work now. Tough pill to swallow but gets it over with. She’s running sweet!
Fortunately I’m very friendly with the mechanic who fixed her so mates rates and discount on genuine parts 👍🏻👍🏻
Post #633014 26th May 2022 11:16pm
dhallworth
That’s some amount of work you’ve had done!
I see you’re in Lanark, who did you use to do it all?
Now you’ve done all of that, if you do the niggles that are outstanding as well you’ll have a properly sorted car on your hands. Selling one with a list of niggles such as wheel bearings, etc. will put a lot of prospective buyers off bringing your value down unfortunately.
Post #633015 26th May 2022 11:41pm
RichardHL3222010
I am indeed just outside Lanark but my friend is in Leicester
So it spent a few months down south
Post #633017 26th May 2022 11:54pm
Superspoons
I would be inclined to keep it after spending all that money on it - it's worth more to you than someone will be willing to pay I feel. Gavin
https://www.youtube.com/@ChallengingClassics
Post #633037 27th May 2022 8:35am
JayGee
Agree it makes little sense to sell if you have sunk that much money into it. I’d be a bit concerned about the turbo fail as it would suggest prior issues with oil supply which may have consequences elsewhere in the engine as these very rarely fail on these engines. 2012 TDV8 Vogue (L322)
Post #633043 27th May 2022 8:40am
