Home > Technical (L322) > Balanced Brake disks
JayGee
Ordered genuine LR rear disks and noticed different length cutout grooves on the outer edge which I assume is material removed to balance them given their size and mass.
Anyone seen this on non LR disks? 2012 TDV8 Vogue (L322)
Post #633072 27th May 2022 3:59pm
Phoenix
All brake discs have to be balanced, otherwise they'd play hell with the dynamics and give you persistent wheel bearing issues.
IIRC OEM ones are +/- 1.8g., aftermarket ones are usually a greater tolerance which increases as the price decreases.
Post #633074 27th May 2022 6:42pm
RiverBlanche
Hi,
yes just fitted rear discs, pads, shoes none gen and as above ^ they have machining slots to the discs.
Tyres can also have marks on them to aid the fitters before balancing, ISTR yellow or Red dots to show the heavy spot of the tyre.
your going to be looking for the spots now aren't ya Laughing
tis true Thumbs Up
Post #633077 27th May 2022 7:09pm
Merchy
Now it's yellow and red dots, this is no good for my OCD, now I've lost my magnifying glass....NURSE!!!!!Thud
Post #633081 27th May 2022 8:16pm
gettingold
See you see red and yellow dots, I hear RED light Green light Shocked, nearly broke out in a sweat. Still though RB I never knew that Thumbs Up Hunt for a L405 is on.
Post #633089 27th May 2022 9:56pm
