Home > Technical (L322) > Slight power loss 2300 to 2500 rpm - 4.4 TDV8
Page 3 of 3 <123
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
I have been watching a chap in Germany who restores BMW's he has his MAF sensors reconditioned when he cannot get hold of them new. The company that does them have said cleaning a MAF sensor makes no difference to it at all, when it is out of tolerance it is out and no amount of cleaning restores it. they only way is to referb or replace!!
he routinely replaces them especially on his older cars as part of the engine service process he goes through. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #633116 28th May 2022 8:16am
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
hotpotatojr wrote:
Great thanks. I'm looking to do the same but also DPF coded out but I'm up north so looking for someone reputable.
What's your feedback on the ECU and TCU updates?
Thanks
For me, it’s hard to say if there was much difference. For the ECU I see no difference but I’m having this power loss issue which may mask any changes.
The TCU was done along with the gearbox mega flush. Again, any improvement is lost with the benefits of new oils. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #633117 28th May 2022 8:28am
Ffrr-lover
Interesting. That’s the first I’ve heard that… not that it means much coming from me Laughing
I’ve swapped my MAF sensors as suggested by GraemeS and will take a drive later to see if there is any change. I also cleaned them again for good measure. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #633118 28th May 2022 8:36am
Ffrr-lover
Swapping the MAF sensors made no difference so booked the car in at a local garage to check the vacuum pump and lines.
Typical… I took the car for a drive to ensure she was warm for the garage and she drove beautifully. There is a slight dip in power still but if I wasn’t looking for it I wouldn’t have noticed it.
All vacuum tests came back showing no issues and their other visual checks couldn’t find any issues.
Frustrating that I’ve paid for some investigation work and they couldn’t find anything. That being said, at least I know my vacuum pump is good.
I may swap the hoses for new silicone ones just in case there is a slight leak that comes and goes due to engine vibrations??? A stretch I know, but for relatively little effort why not. At 120k on them it wouldn’t hurt. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #633509 2nd Jun 2022 7:52am
JayGee
Nothing wasted if you have eliminated something from the list of suspects. I’d log some live data with the GAP tool - MAP and fuel pressure vs rpm. There is also commanded ( ie what the ecu wants) vs actual values which will be useful.
Never noticed a dip on mine but I never go over 2500 rpm……. 2012 TDV8 Vogue (L322)
Post #633517 2nd Jun 2022 9:17am
hotpotatojr
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
If it helps I recently swapped my vacuum lines using the hose in the link below. I bought 2m of 6mm and 2m of 4mm. Some pipes need to be adapted on one end so what worked well was some silicone spray on the 4mm and push into the 6mm. Then chop it flush, if that makes sense!
https://www.ebay.co.uk/itm/403428130792?mk...media=COPY
Post #633518 2nd Jun 2022 9:20am
Ffrr-lover
Which engine do you have? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #633957 7th Jun 2022 8:26pm
hotpotatojr
4.4 tdv8
Post #633970 7th Jun 2022 9:48pm
Ffrr-lover
Ah, I thought I replied to this??? When I looked the 6mm hoses were out of stock.
I just checked again, and have now ordered the hoses. A little job for this weekend along with tracking down an accessory belt chirp. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #634672 15th Jun 2022 8:18am
Page 3 of 3 <123
