Home > Technical (L322) > Slight power loss 2300 to 2500 rpm - 4.4 TDV8 |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 632 |
For me, it’s hard to say if there was much difference. For the ECU I see no difference but I’m having this power loss issue which may mask any changes. The TCU was done along with the gearbox mega flush. Again, any improvement is lost with the benefits of new oils. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
28th May 2022 8:28am |
Interesting. That’s the first I’ve heard that… not that it means much coming from me I’ve swapped my MAF sensors as suggested by GraemeS and will take a drive later to see if there is any change. I also cleaned them again for good measure. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
28th May 2022 8:36am |
Swapping the MAF sensors made no difference so booked the car in at a local garage to check the vacuum pump and lines.
2nd Jun 2022 7:52am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2637 |
Nothing wasted if you have eliminated something from the list of suspects. I’d log some live data with the GAP tool - MAP and fuel pressure vs rpm. There is also commanded ( ie what the ecu wants) vs actual values which will be useful.
2nd Jun 2022 9:17am |
hotpotatojr Member Since: 05 Oct 2021 Location: Blackpool Posts: 69 |
If it helps I recently swapped my vacuum lines using the hose in the link below. I bought 2m of 6mm and 2m of 4mm. Some pipes need to be adapted on one end so what worked well was some silicone spray on the 4mm and push into the 6mm. Then chop it flush, if that makes sense!
2nd Jun 2022 9:20am |
Which engine do you have? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
7th Jun 2022 8:26pm |
4.4 tdv8 |
7th Jun 2022 9:48pm |
Ah, I thought I replied to this??? When I looked the 6mm hoses were out of stock. I just checked again, and have now ordered the hoses. A little job for this weekend along with tracking down an accessory belt chirp. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
15th Jun 2022 8:18am |
