Home > General (L405) > Do L405 rust like 322 ?
Tiny Timmy
I'm thinking of moving into a L405 from my 322, but I wondered do they rust like the 322s ? My 322 (2012) is fine at the moment but I'm thinking long term..........TT
Post #633207 30th May 2022 7:50am
mjdronfield
They have an all aluminium body, so shouldn’t rust on the outside.
I have seen a horror pic of underneath though, where LR put steel and aluminium together…. Corrosion where the rear sub frame meets the body.
Can’t remember the thread name…
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #633209 30th May 2022 9:02am
AnotherMutley
Wasn't it one of Mikey's posts, remember it as well, not good to see.
Post #633211 30th May 2022 9:11am
mjdronfield
This one….
https://www.fullfatrr.com/forum/topic61477.html
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #633226 30th May 2022 11:39am
AnotherMutley
That was the one I was thinking of.
Post #633227 30th May 2022 11:43am
Tiny Timmy
Blimey , thats frightened me a bit!! I thought they would have solved that for the 405 ??
Post #633230 30th May 2022 12:14pm
That’s always been the issue with Scottish RR’s though… Because they salt the roads for a much longer period…
The 405 Is indeed Aluminium BUT! JLR still bolt steel pipe work to the underside of the aluminium shell, using mild steel bolts! Senseless!
Mine has been rust treated so I don’t expect to have the issues others are having with ACE pipe work etc etc…
Post #633239 30th May 2022 1:12pm
CS
My experience with 322 and 405 in Scotland has been that my 2004 322 was pretty good for corrosion, after nine years there was hardly any other than brake lines. It was waxoyled underneath from new though. My 2012 322 was strikingly poor, with corrosion on the rear wheel arches having to be treated every year from year two/three, a new upper tailgate, various window trims replaced, wheels replaced, brake lines needing treated from year three, all due to corrosion. It was really disappointing.
My 405 has had bolts around the headlights and one behind the lower tailgate replaced due to galvanic corrosion. The aluminium trim strip across the tailgate (which includes the number plate light mounts etc) has been replaced twice due to corrosion, the second time after only a year. Various parking sensors have been replaced due to corrosion, the delamination of the covers leading to false positives, some have been replaced twice, the second time after under a year. There is at present a claim with LR on corrosion under the paint of one of the door handles. I expect to be told to "go away" on that. I worry that there are hidden problems of the kind highlighted by Mikey, but short of taking the car apart can't tell. The external panels seem fine.
At the L460 launch I asked what LR had done to address galvanic corrosion. The only comment was that they were using a new platform, and it will be too early to say what (if any) difference that makes.
My general view is that LR have decided to produce cars to a single standard/cost having regard to conditions in all of their markets around the world, rather than try to suit the requirements of the most demanding markets (such as Scotland, wet and heavy use of salt). They provide a corrosion warranty and most (but not all of the time) replace corroded parts during the warranty period. Back in the day of the P38 I think they really tried hard to do their best as regards corrosion, using galvanising, anti chip paint and then normal paint on top. That stopped with the 322 and it may be that "greener" paints and lighter alloys are a factor too. But I suspect they think of the "life" of the car as being from new until it is no longer suitable for the LRAU programme, after that it can crumble to dust and owners take their chances. That is a pity having regard to (a) how good a car it is to use and (b) the ever increasing prices. But what would be better? Only Range Rovers since 1988
Post #633249 30th May 2022 2:25pm
Tiny Timmy
Thanks for all your advice, I'll have a think on it.
The 405 is obviously better but still vulnerable I guess.?
Post #633296 31st May 2022 7:18am
C.S. One more point to add to your post, BMW owned JLR during P38
& 2003-2006 MY 322… Then it was Ford and their cost cutting which imho made the 2nd gen 322 rot more… Then in 2009 Tata took over and used even cheaper steel again and hay presto! Rotted quicker than ever before!!!
Post #633334 31st May 2022 11:20am
Baltic Blue
I agree Craig….. The bodywork on my 2003 L322 was better than the 2011 4.4tdv8 I replaced it with from day 1, but I got the 2011 treated with Dinitrol as soon as I got it and 8 years later it still gets glowing comments how good it is come MOT time.
Post #633363 31st May 2022 4:24pm
