Home > Maintenance & Mods (L405) > First oil change - please help a fool
Page 2 of 3 <123>
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Thanks, Mike.
Is that the "oil filter cap socket" or just a standard 36mm one? What do I put here then?
Post #633323 31st May 2022 10:21am
Baltic Blue
https://www.ebay.co.uk/itm/191485109922?mk...edia=EMAIL G reg 2.5VM Vogue Portofino red 1991- 1999
Post #633324 31st May 2022 10:25am
GAC23
That's brilliant. Thank you so much, Mike.
Will get ordering the socket and torque wrench.
And the oil & filter.
Can anyone point me at where the suction tube on an SDV8 is please? What do I put here then?
Post #633328 31st May 2022 10:58am
GAC23
Sorry ... one more question.
Is this oil ok to use:
https://www.smithandallan.com/products/pas...-m2c934-b/
Only ask as it seems so cheap. What do I put here then?
Post #633329 31st May 2022 11:04am
found this in the WM, should help,
https://www.fullfatrr.com/gallery/albums/u...ILLING.pdf ... - .- -.
Post #633330 31st May 2022 11:05am
GAC23
Thank you, @Stan What do I put here then?
Post #633331 31st May 2022 11:06am
Baltic Blue
That oil is the correct specification and a bargain price.
The 20 litre container might be a bit heavy to handle because you will have to measure out each litre to get the correct amount, but will do two full changes with a bit to spare.
Post #633355 31st May 2022 3:18pm
GAC23
Thanks, Mike.
Will have to go for 2 5l as nowhere to store the big boy.
Everything I need now ordered.
The "fun" will shortly commence. Very Happy What do I put here then?
Post #633356 31st May 2022 3:29pm
Baltic Blue
Just a little tip,
The MAPT sensors get very dirty and clogged up on the 4.4 tdV8, …It only takes 5 minutes to remove and clean it, so I always do it at the same time as changing the oil.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #633358 31st May 2022 3:44pm
GAC23
As a spanner numpty, I'll start by getting an oil change right, then progress. Very Happy
Thanks again for all your help. What do I put here then?
Post #633360 31st May 2022 3:47pm
kevin-t
Touch wood.....Thats the only thing that has put me in limp mode in my 4.4 sport upto Now! mechanic new straight away as soon as I told him fault code of iid tool.
Says its common problem, getting chocked up👌👌👌👍....
Post #633364 31st May 2022 4:26pm
supershuttle
This better be easy as inspired by this and other posts I'm going to buy the tools and the oil and filter and have a go myself - what could possible go wrong? Very Happy
All now ordered except the filter where do I get that from? Geoff
Post #633368 31st May 2022 5:23pm
knwatkins
LR022896 from LR
OEM is Mahle OX153/7D2
Just search online. ECP will stock locally. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #633391 31st May 2022 8:20pm
Gremlin500
……….. V6 Vogue - “Less is More” - less to go wrong!
Post #633402 31st May 2022 9:45pm
GAC23
Thank you @Gremlin500
All the bits ordered.
First part - the filter - arrived from Duckworths earlier.
@BalticBlue has inspired me with confidence. I hope this is as easy as it sounds.
Had a look under the bonnet last night. Assuming this - circled in red - is where I connect the pneumatic drainer?
Post #633438 1st Jun 2022 9:40am
Page 2 of 3 <123>
