![]() | Home > Technical (L322) > 08MY L322, unexpected behaviours |
From memory, this was the era when JLR stopped you using things like nav whilst moving so it sounds normal sir... |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631
I know what you mean, however, L319/L320 of the same vintage don't have that restriction (although different tech.) It has the Nav. 'update' allowing partial input on the move, I've been through the customer / BCM options and 'unlock on key out' isn't one of them. |
Yes the unlock on key out is not supported on pre 09MY facelift cars sir… |
Thanks for that, time to look for a workaround.... |
Well I had cause to disconnect the starter battery, after reconnect, the instrument pack info display and indicator stalk button now work as expected with the vehicle moving - strange.
Well I now have the mirrors folding on lock / unfolding on unlock and 'do nothing' on speed locking working, I would have got the 'unlock on ign. off' working but let down by Royal Mail (not unusual TBH).
For anyone casually following this, I now have 'unlock on ignition off' working, turned out to be more than just a relay and a couple of diodes required....
| All times are GMT |
