![]() | Home > Maintenance & Mods (L322) > Learning to change oil and filters |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 697 ![]() ![]() ![]() |
Think we may need to know what engine you have first? I believe there’s different methods if you have a 3.6 tdv8 or a 4.4tdv8. If you look in the “Wiki” on here, I think there’s probably a section on how to do it.
Vipster Member Since: 09 Jun 2022 Location: Gloucestershire Posts: 12 ![]() ![]() ![]() |
Thank you for replying |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 490 ![]() ![]() ![]() |
If your not confident doing the sump plug method you could always use a pump to suck the oil out, the 4.4 is designed to do this and has a small tube left hand side of the engine (as you look at it) for you to attach the pump to.
Thanks Dave. Suction pump might be the way to do it. I need to now get a 36mm socket and wrench. Air, Pollen and fuel filters, are they straight forward to do? |
You say 4.4 but is that petrol or diesel? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
It's the 4.4 diesel |
Air and pollen are easy, you have two air filters on the TDV8, one either side, decent cross head screwdrivers to remove and clip the maf sensor plug off. Pollen filter slides in at the back of the engine bay, there are 4 tabs you push down and a flap lifts exposing the filter, the fuel filter although not difficult to change needs to be done correct, and once fitted the ignition cycled several times to bleed the system. Again there’s lots in the wiki on servicing. Also on YouTube if you type in raymies garage he does a fuel filter change all filmed.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3313 ![]() ![]() ![]() |
Have a watch at this video for the 4.4 TDV8.
Thanks Dave. Watched them both , very helpful videos . They make it look really easy |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4341 ![]() ![]() ![]() |
It's not. Follow Sam's video and the Wiki instructions on here plus the workshop manual is in there too. Get all the right kit, read up the documents and set aside plenty of time to do it slowly and methodically |
Thanks. I will definitely give it a try. It might all end well |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3298 ![]() ![]() ![]() |
An oil change using suction on the 4.4 is the easiest and least messy of any car I’ve owned. I’d also do it more frequently (every 5-7k) than the recommended service schedule if you are keeping the car long term. 2012 TDV8 Vogue (L322) |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
The 4.4 TDV8 does not have a sump plug as such, so I suggest you are reading the maintenance procedure for the wrong engine. It has a drain hose you manually unclip for engine oil changes. The correct procedure is available in the Wiki. You will also need a 36mm socket and torque wrench capable of going down to 30Nm, irrespective of whether you dump or suck the oil. Air filters simply require a screwdriver with extension (i use a ratchet screwdriver to make life easier). Pollen filter needs no tools at all. Fuel filter needs a rubber strap wrench (it is possible by hand but the wrench makes life easy). If dumping oil, you'll also need a container suitable of taking 9 litres of oil, plus rags/paper towels and brake cleaner/degreaser for cleaning up afterwards. This is the schedule I follow: Every 7,500 miles: Oil and oil filter (I get Petronas 5000 FJ from Opie Oils and a Mahle OX 153/7D2 filter) Every 15,000 miles: above plus 2x air filters plus pollen filter, brake fluid test Every 2 years: fuel filter change, coolant change, brake fluid change 2015 Range Rover Autobiography 4.4 SDV8 Last edited by garyRR on 9th Jun 2022 4:34pm. Edited 1 time in total |
Thanks both.
