![]() | Home > Technical (L322) > Aircon problem |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 339 ![]() ![]() ![]() |
I don’t specifically know that fault code, but there is a known problem with a pressure valve/sensor mounted on the A/C compressor itself.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 778 ![]() ![]() |
have you checked the gas pressure? |
Refrigerant pressure can be misleading, especially on warm days, you need to recover the refrigerant and compare the amount to the specified charge amount. |
It's a good place to start looking as no gas = no aircon |
If there's no pressure then yes, if there's some pressure, it can and has led people to think it's not a lack of refrigerant (and therefore a leak) that's the problem. |
Paddocks67 Member Since: 17 Apr 2020 Location: Glasgow Posts: 28 ![]() ![]() |
Hi lads.i have put a can of stop leak in and a can of refrigerant,the gap iid tool says it has 40 bar of pressure |
It's way too high, I'd suspect the sensor or the connection to the sensor - are you sure the reported measured value is reliable?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8741 ![]() ![]() ![]() |
Blimey, that's 580psi, IIRC maximum should be somewhere near 160psi Pete
Up to 250 PSI with the system running normally and an ambient of ~40 deg. C. |
I will check again tomorrow,to see if the reading has went down any, |
Hi lads I have checked again,it still says 40 bar on the iid tool,and still have refrigerant pressure fault 0x9 showing up,cheers pat |
Also as soon as i turn urn aircon on,the fan kicks on right away,is that normal I can't remember if it done that before when it was working,cheers pat |
It does sound like a faulty pressure sensor TBH, try disconnecting it and see what reading & DTC you get. The fan running constantly is because it sees the pressure as excessive and is trying to cool the refrigerant sufficiently to lower the pressure. |
Thanks for the reply,I will try that tomorrow and see what happens,cheers pat |
