Home > Technical (L322) > Replacement starter motor issue |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
i have a 4.4TDV8 that every now and then would just click and thought it may be the starter issue. any how before i got to change the starter out my battery failed so replaced that. since then it has not happened!!! 2012 Vogue 4.4 TDV8 - Current
11th Jun 2022 11:32am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1132 |
I think you will find the same bottom-end so should be the same as 2010 onwards? I believe that the 4.4 v8 were all the same engine maybe they have given you one for a 3.0
11th Jun 2022 11:39am |
4040 Member Since: 19 Sep 2019 Location: Cornwall Posts: 44 |
Having looked into it in more detail Opies web site....
11th Jun 2022 11:55am |
If anyone could confirm what there part no was for a 2012 one, that would be a help to |
11th Jun 2022 12:03pm |
The main problem with the starter is the solenoid the contacts get carbon build-up which can be cleaned off?
11th Jun 2022 12:08pm |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 |
You need a DSN 1207. |
11th Jun 2022 12:17pm |
Thanks for the replies.
14th Jun 2022 8:01pm |
Sarchopperman Member Since: 11 Aug 2017 Location: Aberdeenshire Posts: 32 |
I had a similar problem. Opie oils website identified my 2012 TDV8 4.4 L322 as an L405 and supplied a Denso Starter DSN 1420. I have a 2011 TDV8 4.4 which Opies site correctly identifies and provides the DSN 1207.
19th Oct 2022 4:55pm |
