![]() | Home > Technical (L405) > DPF Regeneration Issue |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
you have an air leak, either your plenum pipes (there are 4) or an inlet manifold. Get a HIGH pressure test done asap.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
It's not the DPF that is root cause so cleaning it won't fix it.
Pat Member Since: 20 Nov 2016 Location: Airdrie Posts: 66 ![]() ![]() ![]() |
Hi there Im in Airdrie but I go to dundee fairly regularly so I might try Mickey. I am trying to understand the relationship between an air leak and the cars inabilly to do a regen any advice on this would be aprrieciated thanks |
theres loads on this on the forum, do a search..also theres a massive thread in the L322 section that will explain what you need to know..
Thats great I will have a look and get in touch with Mike in Dundee |
If your car wont regen then stg is inhibiting the process. could be a number of things. Temps not high enough to complete. speed not in range. Less than 1/4 tank of fuel. etc et.
or just take it to Mikey and save yourself a heap of time, effort and searching on here.
