|  | Home > Technical (L405) > DPF Regeneration Issue |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3285      | you have an air leak, either your plenum pipes (there are 4) or an inlet manifold. Get a HIGH pressure test done asap.
|  13th Jun 2022 7:34pm |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | It's not the DPF that is root cause so cleaning it won't fix it.
|  14th Jun 2022 7:01am |
| Pat Member Since: 20 Nov 2016 Location: Airdrie Posts: 68      | Hi there Im in Airdrie but I go to dundee fairly regularly so I might try Mickey. I am trying to understand the relationship between an air leak and the cars inabilly to do a regen any advice on this would be aprrieciated thanks | ||
|  14th Jun 2022 8:39am |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | theres loads on this on the forum, do a search..also theres a massive thread in the L322 section that will explain what you need to know..
|  14th Jun 2022 8:44am |
| Pat Member Since: 20 Nov 2016 Location: Airdrie Posts: 68      | Thats great I will have a look and get in touch with Mike in Dundee | ||
|  14th Jun 2022 8:48am |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3285      | If your car wont regen then stg is inhibiting the process. could be a number of things. Temps not high enough to complete. speed not in range. Less than 1/4 tank of fuel. etc et.
|  14th Jun 2022 10:27am |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | or just take it to Mikey and save yourself a heap of time, effort and searching on here.
|  14th Jun 2022 2:10pm |
| Posting Rules
