Home > Maintenance & Mods (L322) > Juddering and shaking at WOT
Page 1 of 4 1234>
Danwilderspin
Ok couple of points to make first
4.2 supercharged 130k.
LPG converted BUT not currently in use.
I have also reset the adaptations.
Right so what’s happening? So I plant my foot on the floor and it’s smooth up to 4-4.5k then it shakes and there no more power like it’s out of fuel, and it’s stinks.
I then let the revs drop back down and it’s fine.
I have no faults… any ideas? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #634791 16th Jun 2022 4:01pm
Blocked fuel filter would be my immediate guess.... Thumbs Up Pete
-Click here for Thread-
Post #634792 16th Jun 2022 4:11pm
Danwilderspin
I’m not saying you’re wrong - In fact it’s a good shout but playing devils advocate, why does it run nicely the rest of the time? Only partially blocked?
Also shouldn’t I be getting fuel pressure faults then too? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #634794 16th Jun 2022 4:36pm
You need more fuel at higher revs, it can't supply enough...
You would think it would throw a code but I have heard of numerous times when it doesn't...
It tends to be more common on diesels because of the bacteria that grows in it if left for a period of time...
With no codes and the symptom you describe I'd change the filter and chuck a bottle of BG44K in it to start with, pretty cheap fix if it works... Thumbs Up Pete
Post #634795 16th Jun 2022 4:53pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
You say it stinks? in what way?
A blocked CAT can give off odd odours and it fits with you symptoms.
J BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #634799 16th Jun 2022 7:37pm
dhallworth
Our local specialist told me that it’s quite common to see melted cats on the 4.2’s.
Can you remove the lambda sensors and stick an endoscope in to see what the internals of the cats look like? It should be a find honeycomb but apparently it’s not uncommon to see a molten mess. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #634801 16th Jun 2022 8:11pm
Danwilderspin
That would be incredibly annoying as I changed both last year for low mileage used ones - good idea I have a scope it’s going to get bushes tomorrow so will check over the weekend .
I do have a cheap cat for one bank not blocked but occasionally threw a cat fault so if it is that bank it would get me out a bind I guess Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #634804 16th Jun 2022 8:55pm
Danwilderspin
So a little update here i went into the tank and was about to change the filter and or pump I pulled the filter and there is a T for the lpg fuel return - normal… but there was some crap wedged where the bore changed for the T … this would be restricting at higher rpm/load I imagine. I’ve ordered a bigger bore T Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #635156 21st Jun 2022 11:17pm
dingg1
If that smaller bore is designed to be the restriction for the fuel return to satisfy the lpg requirements, you will probably have opened another can of worms unless you have another restricter in the line.
Post #635165 22nd Jun 2022 8:46am
Danwilderspin
Already thought of that there was a restrictive screwed into the Tee which I’ve moved into the new Tee Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #635172 22nd Jun 2022 11:14am
dingg1
Post #635173 22nd Jun 2022 11:43am
Danwilderspin
Right little lunchtime update… but the new T in with a nice big bore so no restrictions (except where required!)
Cleared the adaptations and went for a drive it now drives nicely until 5300-5500 and if my foot is flat down I get the juddering again but I had the window open today as it was hot and it sounded like I was getting pop from under the front of the car while this was happening… any ideas Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #635188 22nd Jun 2022 4:51pm
dhallworth
Where was the popping noise coming from?
If it sounded like it was at the front of in the exhaust it could be a backfire causing it to pop. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #635189 22nd Jun 2022 4:58pm
Danwilderspin
I’m not sure maybe the cat or maybe the engine - didn’t sound like a exhaust pop you can force.
I think just to rule out the fuel return as I’m not using gas right now I’ll cut the return out for testing. Will clear adaptations and do this and come back later Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #635194 22nd Jun 2022 6:23pm
dhallworth
My car has an electronic fuel return fitted. When it’s not on LPG it cuts the power to the solenoid so there’s no fuel return. Is yours similar? If it’s returning fuel constantly you will have low fuel pressure. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #635196 22nd Jun 2022 6:38pm
Page 1 of 4 1234>
