Home > Maintenance & Mods (L322) > 2012 tdv8 rear brake refresh |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2973 |
Have you still got the old pads?
23rd Jun 2022 10:43pm |
JAD Member Since: 19 Oct 2020 Location: Wirral Posts: 30 |
Images added.... |
Yep, mark from the piston is more central on the old pads! |
23rd Jun 2022 10:45pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 695 |
Are you sure that you’ve got the calliper mounting brackets on the right wheel?
23rd Jun 2022 11:12pm |
Think its just the camera angle, they've not been swopped over... |
23rd Jun 2022 11:24pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2656 |
It doesn't look right but I can't see why. I did my rear brakes the other week ( Disks, Pads and Callipers) and am sure they didn't look like this. You can rebuild the old callipers with new seals and pistons as long as there is no scoring of the bores. The parts are not expensive and I'd have gone that route but for the fact I needed to do it quickly. The pistons are very difficult to remove if seized. 2012 TDV8 Vogue (L322) |
24th Jun 2022 9:35am |
I was the same and went new for a quick swap rather than refurb and it possibly not work.
24th Jun 2022 9:44am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Can you not compare a new and old calliper, the new ones are either smaller or the mounting holes are further out than the originals, or some other discrepancy which should be noticeable if you have them side by side... Pete
24th Jun 2022 9:56am |
They do look slightly different different but I'd put that down to them being 'aftermarket' Supplier has now come back to me saying they're not suitable which is a complete contradiction to what they told me when I ordered them so they're going back!
24th Jun 2022 10:04am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1336 |
The original calipers were made by TRW. If you buy the TRW part, they're the original OEM caliper, they just have the Land Rover logo blanked off
24th Jun 2022 8:04pm |
Thanks Gary,
25th Jun 2022 5:20pm |
If you can get the bleed valve and piston out and the cast looks ok without corrosion in the chamber, the Frenkit 245918 kit is the refurb kit you need. There's various sellers on ebay. 2015 Range Rover Autobiography 4.4 SDV8 |
25th Jun 2022 5:32pm |
The post 2010 rear callipers are similar to the early front callipers some tips here if you are going to do them yourself..
25th Jun 2022 6:50pm |
Thanks for your comments! Reverted to the refurb option. Old calliper media blasted, etch primered and painted and new Frentech piston and seal kit fitted.
27th Jun 2022 10:15am |
