![]() | Home > Technical (L405) > Electric rear seats |
| garr10210 Member Since: 15 Nov 2013 Location: Scotland Posts: 12
Did you ever get anywhere with your repairs? I have the exact same issue. Although when the you push the boot button the drivers seat will move briefly then stop. |
| Dem75 Member Since: 22 Mar 2021 Location: Grimsby Posts: 7
Nope but it’s going into JAS near York in April. I’ll let you know. My drivers seat moves too. |
Hopefully it turns out to be an easy fix and let us know how you got on. Cheers |
| marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 99
Mine just out of the blue went from being all good to working perfectly fine going down, but would not come back up, RHS rear only..
Thanks for that info, tried multiple combinations of it but the seat still won't move. Thankfully it in the upright position. I have it booked into the most local independent specialist on the 25th April so fingers crossed they get it. Thanks again |
Hi. Not sure if you got yours sorted. Mind turned out to be a small fuse behind the glove box. All working fine now. Cheers |
Thanks, I took it to a local independent but their dignostic software would not connect to my vehicle. I believe a newer version. So living with it fo now until I goes back to lr. I will check the fuses at the front. Do you know the exact one? |
