![]() | Home > In Car Electronics (L322) > Radio doing nothing |
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 207 ![]() ![]() |
I'd check your battery voltage if I was you. When my car had been in for the rust to be taken care of the radio would come on for 30 seconds then go off again. Once I charged the battery up it seemed fine.
... or melted some of the fibre-optic cable front to back. Just displaying the LR logo is a typical indicator of a MOST break. |
Joek0 Member Since: 29 Jun 2022 Location: Tipperary Posts: 50 ![]() ![]() |
Ok I will check connections in boot, are they located on the left side.?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8797 ![]() ![]() ![]() |
There is a loom running on top of the sill area from the back but I'd be very surprised if it got melted unless you had extensive corrosion... but you never know...
Yeh the corrosion was the outside sill i dont think it had spread to the inside. I hope it hasn't melted thats all I need ive only had the car 3 weeks and drove it twice, its driving me mad already |
There's wiring harness' over both rear arches, TBH it's been a long time since I had the interior out of a L322, the MOST will run over one of them though, I think it's the LH, which then crosses over to the centre in line with the 'B' pillar and on to the dash from there. |
Yep, try a battery reset first - make sure it's well charged first though.
Excuse my ignorance but how do I do the battery reset.?
Ignition off / key out for a min of 6 mins, disconnect -ve pole of the battery for another 6 mins (having made sure it is well charged first!) then reconnect, put the battery terminal back in one, positive movement to avoid contact arcing which can temporarily 'spike' some of the modules (if you do get contact arcing, don't worry, just leave disconnected for another 6 minutes) leave for a couple of minutes for everything to 'settle down' before putting the key in.
JLR say to take both terminals off and touch them together but I can't see the point, if the battery is disconnected can't see it making any difference, what Phoenix said works for me as well, as he says the reconnection of the - needs to be a deliberate act....
Unless it's HF strike welding, it's actually better to leave the battery connected as it's effectively a large capacitor and will absorb all the spikes, MIG / TIG welders and Plasma cutters are specifically rated for vehicle repairs (or not!) and will not damage any electronic modules within a specified distance. GYS machines are approved by most vehicle manufacturers for use in body repairs to their vehicles, they're not cheap, and that's one reason why. I have one of their Plasma cutters that I regularly use for removing exhaust sensors that are seized in without battery disconnection - yes, a spark eroder would be preferable but they are less than ideal with limited access.
Dunno, it may be an abundance of safety pointed towards consumers? the large (Mfr. approved) bodyshop we use only disconnect the battery if they have to do work in that area or have to move / disconnect the primary cables. They do move the welding set ground clamp around so it's close to the area of work and obviously move or cover up any control modules, harness' etc. to prevent heat or spark damage.
Cheers for the help guys |
