![]() | Home > Maintenance & Mods (L405) > Side steps problem |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
did you use a trf when you wash it . traffic film remover . you will need to use something oil base to get it back i use duck oil etc new vehicle purchase
Tiny Timmy Member Since: 04 Sep 2013 Location: Bucks Posts: 203 ![]() ![]() |
No I just washed it with gtechniq gwash. The car has had a ceramic coat , just before I got it. But other than that nothing . |
okay that is fine i have used that . idone my ceramic coat using gtechniq brands and always use a detailing spray after g3 pro 7193 rapid detailer when dry to help the ceramic coating last . as said you will have to go over it with a oil base product as plastic is part made up of oil base . might sound silly try a drop of engine oil on a rag or as i said duck oil which of the gtechniq brand wash did you use as i see they are marked with a c.l.p. warning mark ref burns may be why the side steps did not like it new vehicle purchase
Thanks for your help I give the oil a go, and let you know |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3310 ![]() ![]() ![]() |
I wonder if the steps have been refinished with something before you bought the car.
Yeah I thought it could be something like that.
Just watch out if you get that on the soles of your shoes as that could be interesting!
Yeah could be , luckily there just for show
mr dhallworth you can not step on them whatever next my god shock and horror 50 lashes thats why they gave you a curtius setting so you can slide in |
Thanks Oggy, I thought gtechniq Gwash was quite mild ? Maybe not |
just had a look at the data sheet ref gwash and it is more like the ipa in it and sodium sulfonate that will mark the side steps . as i said i use or have used it on mine but i have no plastic showing as i have sprayed all mine i have side bars also
Ok, i would think it must very rather then.
the gwash is okay for your coating spot on its just the side steps i see the ratio is 13 ml to every 20 ltrs of water not a lot as it is not cheap stuff maybe cover steps so it does not lay on the top for to long or get some duck oil spray and use be for wash then wash and wipe steps over when you have finished washing new vehicle purchase
Thanks oggy, I'll try that. The engine oil worked great |
