Home > Maintenance & Mods (L405) > Side steps problem
Tiny Timmy
Side steps problem
Not long had the car L405 2013 se , just washed it and the side steps have gone like this !! Won't come off and looks awful!! Both sides the same Any ideas ?
Post #637481 21st Jul 2022 10:37am
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
did you use a trf when you wash it . traffic film remover . you will need to use something oil base to get it back i use duck oil etc new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #637484 21st Jul 2022 10:53am
Tiny Timmy
No I just washed it with gtechniq gwash. The car has had a ceramic coat , just before I got it. But other than that nothing .
Post #637486 21st Jul 2022 10:59am
oggy
okay that is fine i have used that . idone my ceramic coat using gtechniq brands and always use a detailing spray after g3 pro 7193 rapid detailer when dry to help the ceramic coating last . as said you will have to go over it with a oil base product as plastic is part made up of oil base . might sound silly try a drop of engine oil on a rag or as i said duck oil which of the gtechniq brand wash did you use as i see they are marked with a c.l.p. warning mark ref burns may be why the side steps did not like it new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #637487 21st Jul 2022 11:17am
Tiny Timmy
Thanks for your help I give the oil a go, and let you know Thumbs Up
Post #637489 21st Jul 2022 11:30am
dhallworth
I wonder if the steps have been refinished with something before you bought the car.
L405 steps seem to wear badly on the painted surface on the top so it's possible they've been painted before and it's just reacted with water upon washing. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #637490 21st Jul 2022 11:32am
Tiny Timmy
Yeah I thought it could be something like that.
Just pull Engine oil on them like oggy said and after a bit of rubbing it seems to be fine Razz
Oggy will I have to that every wash ? or should it last??
Post #637492 21st Jul 2022 11:48am
dhallworth
Just watch out if you get that on the soles of your shoes as that could be interesting!
I remember rubbing tyre gel on a rag into my Discovery 2 rubber mats when I was a kid as they came up looking amazing. It was like walking on sheet ice in July after I'd done it. Laughing 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #637493 21st Jul 2022 11:50am
Tiny Timmy
Yeah could be , luckily there just for show
Post #637494 21st Jul 2022 11:53am
oggy
mr dhallworth you can not step on them whatever next my god shock and horror 50 lashes thats why they gave you a curtius setting so you can slide in Shocked tiny might be worth looking at a more gentle wash liquid or keep them wet well when washing new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #637495 21st Jul 2022 12:19pm
Tiny Timmy
Thanks Oggy, I thought gtechniq Gwash was quite mild ? Maybe not Rolling Eyes Smile
Post #637496 21st Jul 2022 12:29pm
oggy
just had a look at the data sheet ref gwash and it is more like the ipa in it and sodium sulfonate that will mark the side steps . as i said i use or have used it on mine but i have no plastic showing as i have sprayed all mine i have side bars also
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #637501 21st Jul 2022 1:18pm
Tiny Timmy
Ok, i would think it must very rather then.
Any idea what shampoo to use that is also ceramic coating safe ?
Post #637503 21st Jul 2022 1:51pm
oggy
the gwash is okay for your coating spot on its just the side steps i see the ratio is 13 ml to every 20 ltrs of water not a lot as it is not cheap stuff maybe cover steps so it does not lay on the top for to long or get some duck oil spray and use be for wash then wash and wipe steps over when you have finished washing new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #637504 21st Jul 2022 2:04pm
Tiny Timmy
Thanks oggy, I'll try that. The engine oil worked great Thumbs Up
Post #637530 21st Jul 2022 9:31pm
