![]() | Home > My Range Rover > Back with another Supercharged |
I can imagine David... |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3327 ![]() ![]() ![]() |
The petrol injectors have now been refurbished and are on there way back to me now.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1404 ![]() ![]() |
Hi David
For which bit? |
I’ve not been able to get in touch with the bloke who does the thread repairs this week so I’ve been trying to think how I can drill it out.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8789 ![]() ![]() ![]() |
Good job, hope the extraction goes to plan... |
I bought one of these for one job very similar to yours.
That’s the same idea as the drill I’ve ordered this evening.
Fair enough, photo's can give a false perspective sometimes - do you have some stub drills? I find they're better for getting the cut started as they put less side load on the guide, once a couple of millimetres in past the 'point', that's when I change to a longer fast flute bit - they tend to form chips rather than lots of long swarf so take the heat away from the cutting face quicker.
Done! |
Excellent job on the extraction...
Yep, nice job on the extraction - looking at the size of the torque wrench, you should be OK but watch out for going over limit when using the angle setting, I lent my small one to another tech a while back, he was doing 30Nm + 180deg. the wrench was rated at 35Nm and the +180 took it into 'fault' territory... it still passed calibration checks but had an annoying 'E1' every time it was turned on.
Thanks for the heads up |
