![]() | Home > Maintenance & Mods (L322) > Air Con problem |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
Known issue mate, valve in the compressor
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Sounds like the valve. New compressor time.
longd Member Since: 24 Oct 2020 Location: West Midlands Posts: 95 ![]() ![]() ![]() |
Just noticed it’s been gassed up to the 4 zone not dual so that’s definitely not helping… thanks for the links guys just reading up on it now !! I guess I need to just order a new compressor ! |
If the refrigerant has been overcharged, get that corrected first and see if it improves. |
It’s been over charged today - 611g recovered 890g charged,
Overcharge will stop it working. They need to redo it so it has the right amount, as per the label under the bonnet.
Thanks so much guys , will get the right amount in it and see where I’m at , will start putting the penny’s away for a new compressor lol |
I’ve not seen an answer yet as to whether replacing with the same make unit will mean that you will have the same issue again eventually, or whether the part has been upgraded… or whether a different make compressor won’t have the known issue like the factory one.
It’s on its original one , so lasted 10yrs… I imagine in another 10 years the air con will be the least of my problems lol
Yeah, but you have to take the compressor off to change the valve, so most folk do the whole compressor in case that has an issue soon after the valve swap.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1485 ![]() ![]() |
Please search the forum - there must have been 3 or 4 threads all on exactly the same thing in the last month. You need to remove the compressor in order to access the valve, in which case it's worthwhile replacing the compressor anyway, being 10 years old and how big of a job it is to get to. New compressors come with a new valve. Here's the DIY guide I wrote for the benefit of other members: https://www.fullfatrr.com/forum/topic63889.html 2015 Range Rover Autobiography 4.4 SDV8 |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1324 ![]() ![]() ![]() |
I was fearing my compressor might be at fault but had the system recharged today. For £60 I thought it was worth doing before investigating further. The system had 465 whatever's in it and now has 700 whatever's in and it is now, dare I say toooo coooold!!!!
Yep. That worked for me. For a few months then compressor needed doing. I hope yours stays cold |
Thanks Rob. Fingers crossed. My compressor was meant to have been done just before I bought the car 3 years ago. |
