![]() | Home > Technical (L322) > Hesitation, Red Restricted Perf, hardly runs, codes…4.4 TD |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Looking forward to the diagnosis and fix |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2723 ![]() ![]() |
Has it been confirmed that exhaust gases are getting out the back to indicate that the rear muffler isn't totally blocked in case it has collapsed internally? |
Avityesboy Member Since: 27 Apr 2022 Location: Kidderminster Posts: 24 ![]() ![]() |
Yes mate, it’s been disconnected before the DPF |
Just thinking aloud but black smoke in the inlet could also be EGR related. These are not a common fail on these engines and neither are valve issues. 2012 TDV8 Vogue (L322) |
Is restricted performance still showing with the ign on but the engine not yet started?
Not sure I’ll see when I get it back but I’d have hoped the specialist would have checked that already… |
UPDATE!
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1392 ![]() ![]() |
Not a good advert for Mark Smith is it?
In their defence I’d say it seems very uncommon for engine chain problems on these…nobody seems to have heard of this problem before on these engines…
That is very rare.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1485 ![]() ![]() |
Hmmmm, a workshop should really be viewing an issue with an open mind and know fault codes are often consequential. An engine not running / running rough is unlikely to be exhaust related and more what you started looking at block related e.g. cylinders, timing, injectors. I also havent read of timing chain issues on this engine, only the 5L being a problem. I guess next stop is to a specialist, engine out and heads off to start looking at damage to see whats salvageable? 2015 Range Rover Autobiography 4.4 SDV8 |
Thanks guys, think the next plan is to start stripping it a bit myself as don’t want to throw money at it anymore, it owes me not far shy of 10k urgh..
Anyone know if this is an interference engine? I can’t find anything online.. |
