Home > Maintenance & Mods (L405) > Exhaust Sensor - Or at least the bit the sensor screws into!
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
hi haylands i think steve said that the hole nut has sheared off just leaving the thread in side the female collit new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #635760 30th Jun 2022 10:17am
SteveA
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Thanks oggy - that’s exactly what’s happened. Whether there’s enough of the the "hollow" thread to weld a nut onto - I don’t know. I guess it might be tricky but they have a really good welder who might be up for the challenge. I’ll keep you posted! Thanks again haylands.
Post #635767 30th Jun 2022 12:29pm
colalowe
United Kingdom 2012 Range Rover Autobiography TDV8 Buckingham Blue
Hi SteveA
how did you resolve this? I have just snapped the same sensor and now contemplating removing the exhaust to get the sensor drilled out. 2012 TDV8 Autobiography Baltic Blue
Previous
2007 BMW M5 E60
Post #638318 31st Jul 2022 11:09am
Phoenix
Good luck with drilling them out, we use a Laser Tools 8063 (or one out of the 7337 set if 14mm)socket on them and hope that a good 'snatch' on a breaker bar will release them - it usually does, if not, it's out with a die grinder to take most of the material & sensor away until the wall is thin enough to deform inwards with a centre punch but with one side ground to the profile of the sensor hole, if that makes sense? It's important to not chew up the threads of either the exhaust or the sensor collar trying to get it out before moving on to grinding it out as that just makes an awkward job harder... Other than a clean up with a finishing tap, this approach has worked every time.
Post #638337 31st Jul 2022 1:05pm
colalowe
I think I’m going to have to accept defeat and get a professional to do it, I’m worried I’ll make things worse.
Phoenix do you work in a garage? Fancy a go at it? 2012 TDV8 Autobiography Baltic Blue
Previous
2007 BMW M5 E60
Post #638362 31st Jul 2022 5:26pm
Phoenix
Yes I do but some distance away - there's plenty of places that would be able to do it for you. Depending where you are, try contacting RLD - if he can't do it for any reason, he'll have a mate who can.
Post #638364 31st Jul 2022 5:45pm
colalowe
I’m over in Blackpool, who is RLD? 2012 TDV8 Autobiography Baltic Blue
Previous
2007 BMW M5 E60
Post #638365 31st Jul 2022 5:54pm
Phoenix
https://www.fullfatrr.com/forum/member-rld.html Mainly active on Disco3 but a good bloke and 'old school' engineer.
Post #638369 31st Jul 2022 6:23pm
colalowe
Thanks for that I've sent him a PM, doesn't look like he is active on here so Ill try the Disco Forum as well Thumbs Up 2012 TDV8 Autobiography Baltic Blue
Previous
2007 BMW M5 E60
Post #638374 31st Jul 2022 8:11pm
SteveA
colalowe wrote:
Hi SteveA
To be honest, I'm not sure.
I think they left the old sensor in situ then drilled and welded(?) in a new adapter to fit a new sensor in. They had to order the new adapter in from Germany.
Cost to me, fully sorted, was £448 inc VAT. Bartram LR Services, near Accrington.
It's been 6 weeks now with no issues (touch wood!).
Hope you get yours sorted.
Post #639926 17th Aug 2022 12:32pm
