![]() | Home > Maintenance & Mods (L322) > Removal of rear Wiper/washer Motor: How To with Pics |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
One of my washer jets will not spray water any longer and despite inserting a sewing needle into them it doesn't seem to have any effect.
Larry Member Since: 03 Dec 2008 Location: East Midlands Posts: 262 ![]() ![]() ![]() |
When I had this problem it was sorted under warranty. They claimed to have "reset" the washer system.
I've done the needle in the holes trick and its made no difference at all.
This issue has come and gone a few times but now it needs fixing. Hardly any water is coming out of the nozzle but I've noticed water is obviously collecting in the rear trim where the washer wiper motor is, and then running down the inside of the rear window! (Seems to happen when I accelerate from a standstill)
The only Tool i know is the Technician at my local LR Dealership....... ![]() Sorry Adam ain't got a clue...... Best of Luck ........ ![]() |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2074 ![]() ![]() ![]() |
I think that tool works for things like door cards etc, but the plastic trim in the top tailgate seems to be clipped together, you know the type, go together very well, snap together jobs, but when you want to remove they break, like the rear light cluster!
Dismantled the inner trim surrounding the rear wiper motor/washer, found the problem. Seems the motor has sprung a leak from the centre spindle, no chance of repair, replacement needed. guess a trip to the dealer tomorrow, hopefully not an expensive part.
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1120 ![]() ![]() |
The part is not extortionately expensive but sadly I can't seem to find anyone who sells it other than the Dealer. £126 inc VAT.
You could try here:
Nbunney, this is a RR forum, not a Jag forum!!
I'm only joking with you |
