Home > Maintenance & Mods (L322) > Removal of rear Wiper/washer Motor: How To with Pics
Page 1 of 6 123456>
One of my washer jets will not spray water any longer and despite inserting a sewing needle into them it doesn't seem to have any effect.
I might look to remove the arm and washer jet assembly from the vehicle and check it over, clean it thoroughly etc.
I can see there are 3 bolts that hold the plastic spoiler above it (with the rear 3rd brake light) and then you can get at it. Has anyone done this already and knows if there are any gotchas involved? Discovery 4 HSE
Post #6387 8th Jul 2009 9:26pm
jope
Norway 2003 Range Rover HSE Td6 Java Black
as I looked in Rave there seems to be exactly what you need. Remove the three bolts, close the tailgate and move spoiler aside.
Post #6389 9th Jul 2009 12:05am
Larry
England 2006 Range Rover SE Td6 Java Black
When I had this problem it was sorted under warranty. They claimed to have "reset" the washer system.
I presume reset is the new phrase for "stick a needle in the hole"
Let us know what you find when you get it apart. I have a feeling I'll need to do this job in the future too.
Post #6393 9th Jul 2009 8:48am
I've done the needle in the holes trick and its made no difference at all.
Looks like you need to remove the interior trim at the top centre of the glass to access the pump, motor and pipes (If you need to look at all of the working parts) and I'm nervous about that as I don;t have a trim removal tool and know I will break something. Discovery 4 HSE
Post #6413 12th Jul 2009 12:16pm
This issue has come and gone a few times but now it needs fixing. Hardly any water is coming out of the nozzle but I've noticed water is obviously collecting in the rear trim where the washer wiper motor is, and then running down the inside of the rear window! (Seems to happen when I accelerate from a standstill)
Looks like I'll be taking it apart afterall, fingers crossed I don't break any of the plastic trim clips.
Anyone got any tips on how NOT to break trim when prising apart, what tool to use etc? Discovery 4 HSE
Post #7165 8th Sep 2009 7:29pm
The only Tool i know is the Technician at my local LR Dealership....... Whistle
Sorry Adam ain't got a clue...... Best of Luck ........ Thumbs Up
Post #7166 8th Sep 2009 8:14pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
This any good?
http://www.machinemart.co.uk/shop/product/...ad-remover
Post #7167 8th Sep 2009 8:26pm
I think that tool works for things like door cards etc, but the plastic trim in the top tailgate seems to be clipped together, you know the type, go together very well, snap together jobs, but when you want to remove they break, like the rear light cluster!
If I get time this weekend I'll have a go and document it with the help of Rave.
There will be pics of course! Discovery 4 HSE
Post #7169 9th Sep 2009 12:55am
Dismantled the inner trim surrounding the rear wiper motor/washer, found the problem. Seems the motor has sprung a leak from the centre spindle, no chance of repair, replacement needed. guess a trip to the dealer tomorrow, hopefully not an expensive part.
Watch this space: Discovery 4 HSE
Post #7215 13th Sep 2009 5:23pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Rolling with laughter letters not necessarily in the right order
Post #7218 13th Sep 2009 7:36pm
The part is not extortionately expensive but sadly I can't seem to find anyone who sells it other than the Dealer. £126 inc VAT.
At least its an easy enough swap out and there's not 2 hours labour added on. Big Cry Discovery 4 HSE
Post #7229 14th Sep 2009 2:12pm
nbunney
You could try here:
http://www.jojags.co.uk/ I had a grill off them a bit back
or
http://www.cws4x4.co.uk/ They are always breaking L322, 4 at the mo
Post #7231 14th Sep 2009 5:06pm
Nbunney, this is a RR forum, not a Jag forum!!
I've contacted CWS, lets see if they respond.
Cheers Discovery 4 HSE
Post #7234 14th Sep 2009 7:14pm
nbunney
Sorry for trying to be helpfull,but as I said, I got a grill off them earlier this year.
Perhaps I should of been more specific and said I got a Range Rover grill off them.
Post #7235 14th Sep 2009 7:20pm
I'm only joking with you Whistle
I found a few places breaking range rovers but then you do run the risk of the 2nd hand part also expiring like the one on your own car did!
I'll let you know how it goes.
PS: I do appreciate the help Thumbs Up Discovery 4 HSE
Post #7236 14th Sep 2009 7:25pm
Page 1 of 6 123456>
