![]() | Home > My Range Rover > Back with another Supercharged |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3327 ![]() ![]() ![]() |
For it to be that far out after only 4 or so complete revolutions doesn’t sit right. This is my first time doing a chain, however, when doing belts they always pin straight up every time.
I ventured back out into the workshop last night and checked everything over once more. I pinned the crank and checked the cams and they were just about where you’d expect them to be.
The rest of the parts arrived today, 2 new o-rings for the front cover from Duckworths and a new Denso alternator.
Good idea with the numbering - I've never thought of that over the years... usually a printout taped to a stand, engine mount or wing top - or a laptop balanced somewhere precarious.
There’s 24 bolts on that one so I thought I’d number them just for ease.
Watch the date on the sealant, I've seen some stuff close to it's expiry that never really 'set', eventually the oil pushed a route through it.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8790 ![]() ![]() ![]() |
Excellent, hope it goes back together smoothly.. |
Right… time for an update! Not as much progress as I’d wanted but hey ho!
I feel your annoyance, waiting for parts is the worst bit by far...... |
Just a tad annoying! Like Groundhog Day around here 🤭🫢🫣🙄 |
Have ordered the last few bits from Duckworths this morning.
Changed my mind… those pipes are different diameters at each end and are shaped to fit the brackets on the bulkheads.
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 406 ![]() ![]() ![]() |
Great progress David - always interesting to see where you've got to |
I’d decided last night I was going to replace the PCV valve again. Only this time it was because it had reacted with the degreased I’d used. It looks awful here and it visible once the engine cover is refitted.
