Home > Maintenance & Mods (L405) > Mounting Spotlihgts on L405 Bumper - Is it possible?
Salsbury
Canada 2014 Range Rover 5.0 SC V8 Barolo Black
Thinking about mounting four spotlights in front of the grill.
Interested to hear if anybody has done this and what mounting solution was used?
I did just post similar to rangerovers.net and included a couple of photos:
https://www.rangerovers.net/threads/lookin...05.354168/
Many thanks
Post #638971 7th Aug 2022 9:38pm
dont know about spotlights, they are a bit old fashioned..
some on the forum have fitted lightbars which can be put behind the grill for a stealth look.. ... - .- -.
Post #638980 8th Aug 2022 7:12am
You need a very firm mounting for spot lights or they will wobble about all over the place, the thin plastic bumper cover is not really suitable unless you concoct a bracket to fit behind the bumper to connect it to something more solid...
I'm with Stan, spots are a bit old fashioned though.... Thumbs Up Pete
Post #638996 8th Aug 2022 10:04am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
There are lots of grille-mounted LED spotlight (rather than lightbar) options - sure the Discovery ones can’t be miles away from being made to fit.
Post #639012 8th Aug 2022 11:33am
Salsbury
Re: Mounting Spotlihgts on L405 Bumper - Is it possible?
Yes, Spotlighs does sound a bit 1983. However, I intend to use KC Flex-Era 4 which are some of the more advanced LED "light pods" on the market.
https://www.kchilites.com/flex-era-4-2-light-system.html
Post #639029 8th Aug 2022 2:51pm
Salsbury
Just stumbled up this bracket for a RR Sport. While the bolt holes may not necessarily line up I think the concept would work well on a 405.
Post #639032 8th Aug 2022 2:56pm
Salsbury
I've been aggressively searching the internet for such a solution. Found some inspirational brackets for Discovery 4 and RR Sport but nothing that will fit the L405.
Suspect that I'm in for a custom engineering solution.
Post #639060 8th Aug 2022 7:44pm
Some of the light bar solutions look neat - like these
https://www.fullfatrr.com/forum/topic49329.html?start=18
https://www.fullfatrr.com/forum/topic58490.html
Otherwise I'd agree, custom brackets are probably the answer.
Post #639109 9th Aug 2022 2:19pm
Salsbury
Thanks for those interesting links - I hadn't found those.
Fitting a light bar behind the grille seems an elegant solution when matched with a 2018 style grille.
I've considered this route, but given that my 405 already has a ruggadised look, I thought that four lights in front of the grille will give it a "Paris to Dakar" look!
Post #639117 9th Aug 2022 3:51pm
