![]() | Home > My Range Rover > Absolutely Gutted |
bigdave Site Sponsor Member Since: 27 Jun 2011 Location: Cornwall Posts: 242 ![]() ![]() ![]() |
Thats chuffing awful - sorry mate.
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Bad news |
How many miles and what was the service history? Very rare to have these engines fail internally unless they have been neglected. 2012 TDV8 Vogue (L322) |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 352 ![]() ![]() ![]() |
150k one previous owner with full service history then I’ve been servicing every 6k or six months 2012 Range Rover Westminster 4.4 TDV8
You are very unlucky then. Mine’s nearing that mileage but the trade in value is less than the quote for the engine so think carefully before you commit. 2012 TDV8 Vogue (L322) |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
what were the oil period changes from the history of the last owner? and was it a main dealer or indy or Halfords . it sounds like very long oil changes and very cheap oil has been used . which has made the oil ring or rings sized around the piston. new vehicle purchase
Regardless of the cause, that's gone now - Cost to repair, well, what is the value to you? trade-in value is only what someone else determines it is worth. How big is your 'to do' list? are there underlying issues? if you were looking at an ongoing spend, then cut your losses - if it's pretty sound, then get the engine sorted. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3309 ![]() ![]() ![]() |
That’s a really bad bit of luck |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Try getting a quote from these guys.
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 133 ![]() ![]() ![]() |
Search this topic on hear the noise is said to be expected. 4.4 TDV8 oil filler cap removal
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
Feel for you - I was in a similar position when the GM gearbox on my L322 failed.
If you're on Facebook, look up JPSK Motors.
Is the engine still running fine except for the ticking and noise when you take the filler cap off. |
i would defo do my own investigation on that bank to see if the cyl bores are marked etc get a scope in the bores if the bores are clean could be a new set of rings or try and free them rings up new vehicle purchase
