![]() | Home > My Range Rover > Back with another Supercharged |
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848
And so you should be, well done! |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631
And now comes the great workshop cleanup.... |
| Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 408
Its seen the sun ! Nice fix for the air compressor to |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3348
The wife decided she wanted a day out today so there wasn’t much progress with the car.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
If it were me, and obvs it’s not, I would just get a roll of roofing flashband and stick a patch over the holes….. after all you are never going to see it again, and check periodically if it’s still stuck down. There is nothing that can't be fixed with a hammer😜😜
| Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601
Welding on a car is not for the faint hearted!! make sure you practice to get the settings right on a bit of scrap first then short sharp bursts. As the holes are close together i would move from 1 to the other adding a small blob each time.
After having my Air Con 'checked' and refilled by Kwik Fit a few weeks ago, its now throwing out warm air. I'd like to use my IID tool to see if the compressor is at fault and have a proper leak test done. Can you give me some details of your setup David and if Nitrogen is available to the general public? Gavin
Sure. I bought a cheap set of gauges off eBay. I think they were around 28 quid.
Many thanks David. I'll contact my local air con contact and let them diagnose it properly. I'm pretty sure Kwik Fit just did a pressure test for 30mins, didnt find a leak and then topped it up, but I'll call them and check. Gavin
Kwik Fit will have done a vacuum test.
the vac tests are not that reliable i always get die added and a nitrogen charge. great way to find leaks with the UV lamp and glasses. 2012 Vogue 4.4 TDV8 - Current
have the pressure re-checked if it is still up to pressure you know it is the compressor. Mine went last year and would intermittently work but only when the temp was below 25deg over that it would not work. I changed the compressor and all is well again. 2012 Vogue 4.4 TDV8 - Current 2014 Navara V6 - Gone 2004 Vogue TD6 - Gone Grand Cherokee - Gone Discovery V8 (LPG) - Gone Discovery TD5 - Gone |
Yup… definitely a leak somewhere. 5 bar loss in around 15hrs. This one is going to be a pain to find. A recharge and some UV dye might be the easiest way for this one.
I’d go with a good look at the condenser first, Dye is probably the only way you will find it though. There is nothing that can't be fixed with a hammer😜😜
| All times are GMT |
