Home > Technical (L322) > Aerosus front air springs |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
One of my air springs developed a fault so I have changed both the front ones for Aerosus units. Dampers are fine.
15th Aug 2022 9:59am |
I considered that but as the old dampers are fine and with the active damping are horrendously expensive, I just went with bags.
15th Aug 2022 10:10am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1271 |
I had my front bags changed aerosus, top seals sequence should be, back up ring (white nylon) rubber o ring, back up ring, rubber o ring, back up ring.
15th Aug 2022 10:53am |
I fitted the top seals in the order you mentioned and also gave them a smother of silicone grease which aids assembly and also prolongs their life, it did strike me as off there are three spacers though as the originals only have two.
15th Aug 2022 12:18pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2982 |
Have you heard anything back from Aerosus yet? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
16th Aug 2022 3:14pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
watching with interest 2012 Vogue 4.4 TDV8 - Current
16th Aug 2022 3:29pm |
Sam's Motor & Machine on YouTube had problems with leaking Aerosus airbags that he fitted to the rear that he ended up changing out for a different make so am just curious to see if Aerosus can offer a resolution to make theirs seal.
16th Aug 2022 3:35pm |
Aerosus asked me to do a soap test by which I guess they mean spray it with soapy water to identify the leak.
16th Aug 2022 4:15pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1118 |
I think Sam found that they leaked where the pipe fitting connection was attached to the bag. |
16th Aug 2022 4:32pm |
I hope that's all it is. Christian.
16th Aug 2022 5:50pm |
Today I have removed the air strut from the car and submerged it in a water bath to check for leaks.
10th Sep 2022 11:48am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2312 |
Is the nut tight?
10th Sep 2022 12:48pm |
It’s as tight as I dare go. Christian.
10th Sep 2022 12:56pm |
Are you using a hex socket or similar to hold the shaft? I was surprised how tight mine needed to be to stop bubbles emanating from around the nut, which might indicate a different problem. |
10th Sep 2022 1:43pm |
