Home > Maintenance & Mods (L322) > L322 TDV8 4.4 Turbochargers
Kiss My Carbon Footprint
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
Chaps,
Having trawled the Wiki as well as forum posts, I am seeking a little advice.
With this year's service my Indy and I decided it was time to look again at what had been a relatively minor oil leak when I first acquired the car just over 4 years ago. A "weep" appearing at the time to come from the sump gasket.
A more in depth investigation revealed the primary turbocharger as the source. Replacement was recommended. And with that the secondary likely warranting investigation also.
For info, mileage is now 65k.
With availability of replacements proving tricky, I've starting looking around myself. I've found sourcing the primary relatively straightforward, albeit expensive. And really expensive if we're looking at genuine LR - even with site sponsor discount.
But I'm not sure that a replacement secondary turbo is available anywhere. Certainly lead time for genuine LR is potentially months.
Which brings me to refurbishment. There are plenty of firms out there offering refurbished units on an exchange basis. But how good/reliable are the outcomes ? Does anyone have any experience or recommendations that they might care to share ?
A point to note is that whilst refurbished units are offered on an exchange basis, this also applies to all of the other options I've looked at so far, including genuine LR. Which would seem to suggest that even new offerings might actually be "remanufactured" / refurbished ?
I shall be grateful for any thoughts.
Warwick 2011 L322 TDV8 A/b Orkney Grey
2008 Defender 90 XS TDCi Java Black
2002 L322 TD6 Vogue Zambezi Silver (gone but not forgotten)
And one or two bikes - Ok, maybe more than one or two....
Post #639757 15th Aug 2022 11:52pm
S60R
So I know a few people who have refurbished through turbo technics with good results….. I think a good refurb may be the most economical option with parts being so crazy at the moment.
I think they are based in Northampton…. I don’t know what is involved with removal though? I hope it’s better than the discovery! They were never designed to be easily got at on the sdv6…. I hope the tdv8 is doable without body removal!
If you can get the turbo removed they offer a free collection and re delivery service…. May be worth a call to get an estimate at least?
Post #639760 16th Aug 2022 6:52am
JayGee
65k miles is very low for a turbocharger fail unless it has been severely abused and had zero oil changes. Also worn turbo’s leak internally on the shaft seals and generally not externally so I’d be very tempted to get a 2nd opinion on this or if the leak is minor just live with it. 2012 TDV8 Vogue (L322)
Post #639765 16th Aug 2022 8:01am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Re: L322 TDV8 4.4 Turbochargers
Kiss My Carbon Footprint wrote:
Chaps,
Warwick
Try Midland Turbo's, weve had loads of turbos repaired / rebuilt as well as specialist design builds. Their service is brilliant and quality of work top notch.
J BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #639766 16th Aug 2022 8:12am
JayGee
They did a turbo refurb on an old Saab many, many years ago so good to hear they are still going. 2012 TDV8 Vogue (L322)
Post #639767 16th Aug 2022 8:15am
GraemeS
Australia
Not just a leaking gasket on the drain or the hose clamp not tight enough?
Does the secondary turbo get a frequent work-out to keep the whole inlet tract clean of residual oil?
Has the hose been removed from the bottom of the i/c to drain accumulated oil?
Post #639768 16th Aug 2022 8:16am
garyRR
I'd second JayGee on this. Turbos leak oil through their seals internally and the oil (in small quantities) gets taken through the intake system and burned off through combustion (entirely normal on the 4.4 TDV8 due to the issue with the engine design). I can't see how a worn turbo is going to leak oil externally.
Occasionally it can collect on the lowest point, which is the bottom of the bellowed hose near the front nearside wheel (need to take the radiator splash guard off).
If oil is appearing externally, that's either the oil feed or return hose or a split turbo (unlikely) because you'd also be suffering power loss and all sorts. I think you should seek an opinion from one of the specialists who are regularly mentioned on the site. It's fairly common for the heads on the braided hoses to begin leaking - a quick tighten often resolves a leak.
Without wishing to state the obvious, the most common cause of an oil leak on the 4.4 TDV8 is failed seals in or a warped oil cooler. The oil then makes it's way down the side of the block onto all sorts. I trust this has been investigated and ruled out or already done. 2015 Range Rover Autobiography 4.4 SDV8
Post #639772 16th Aug 2022 8:52am
cass
Not sure how bad your leak is but mine has a receipt from a service before I bought it advising that a new turbo was needed due to an oil leak. It had 30odd tousand miles on it at the time. I've put nearly 100K miles on it and it still has the same leak.
Is it something you can live with?
Post #639788 16th Aug 2022 11:46am
Thanks to S60R and AJGalaxy2012.
Turbo Technics and Midland Turbos were already on my shortlist based on online reviews.
Your endorsements being closer to home are the reassurance that I was hoping for.
My thanks also to JayGee, GraemeS and GaryRR for your thoughts. Agreed, mileage is low for a possible turbo failure. That said the problem ostensibly predates my tenure and so prior treatment of the turbos is an unknown. Additionally the oil leak does appear to have worsened over the last four years.
With regard to other possible causes you will appreciate that I've not conducted the investigative work myself. I do have faith in the garage undertaking the work. A family firm of qualified automotive engineers with whom my family have entrusted all of our vehicles for more than three decades.
I would then expect that they have undertaken the proper due diligence.
That said, I must of course take note of your recommendations and so I shall be asking further questions.
A second opinion may be tricky however as I believe that a certain amount of dismantling, necessary for the purpose of diagnosis, has already been performed.
As I say, the secondary turbo being implicated in this is not yet certain.
Cass - living with the oil leak is kind of what I've been doing to date. A "watching brief" as it were. Were it apparently stable, we'd perhaps not be having this conversation. But as I say, it does seem to be worsening. The increasing resulting oil coverage worsening also as a consequence. My point here is that were something else to happen, adding to this, then this might not be apparent in time to avoid serious damage.
And the oil staining to my driveway although not the primary motivation here, is becoming more noticeable....
I think that's all for now.
Next step - back to the garage for a chat.
Thanks again everyone for your help. Is much appreciated.
Post #639885 16th Aug 2022 10:18pm
RBFFRR
United Kingdom 2011 Range Rover Vogue TDV8 Fuji White
Resurrecting the 3 year old thread to ask the question...what was the outcome and did you get the turbos refurbished? Everything go ok?
In a similar predicament at the moment and considering refurbished turbos. Your choices and experience would be helpful to understand. Thanks.
Post #715999 12th Apr 2025 6:40am
RBFFRR,
Wow, has it really been 3 years....
The short version is that I took the secondary turbo to Midland Turbo for refurb where I found Mike most generous with his time and indeed his knowledge.
The refurb was inexpensive - from memory just under £200 plus VAT. And turned around that same week.
Mike suggested that this might well not have been necessary, but since it was out it seemed sensible to take the opportunity.
Mike also recommended undertaking the "Turbo Drain Mod", suggesting that this might be the true cause of the malaise. This was also done - undertaken by the family firm I've used throughout my adult life.
I don't believe I've seen sign of either oil leak or smoke from the exhaust since completion.
Happy to endorse Midland Turbo.
Good luck in resolving the issue with yours.
Post #716034 12th Apr 2025 5:29pm
RBFFRR
Thanks Warwick, appreciate you replying. I'll give them a bell tomorrow.
Glad you got yours sorted in the end.
Post #716120 14th Apr 2025 11:11pm
