![]() | Home > Maintenance & Mods (L322) > L322 TDV8 4.4 Turbochargers |
| S60R Member Since: 23 Mar 2022 Location: West Sussex Posts: 50
So I know a few people who have refurbished through turbo technics with good results….. I think a good refurb may be the most economical option with parts being so crazy at the moment.
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404
65k miles is very low for a turbocharger fail unless it has been severely abused and had zero oil changes. Also worn turbo’s leak internally on the shaft seals and generally not externally so I’d be very tempted to get a 2nd opinion on this or if the leak is minor just live with it. 2012 TDV8 Vogue (L322) |
| AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464
Try Midland Turbo's, weve had loads of turbos repaired / rebuilt as well as specialist design builds. Their service is brilliant and quality of work top notch. J BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
They did a turbo refurb on an old Saab many, many years ago so good to hear they are still going. 2012 TDV8 Vogue (L322) |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782
Not just a leaking gasket on the drain or the hose clamp not tight enough?
| garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494
I'd second JayGee on this. Turbos leak oil through their seals internally and the oil (in small quantities) gets taken through the intake system and burned off through combustion (entirely normal on the 4.4 TDV8 due to the issue with the engine design). I can't see how a worn turbo is going to leak oil externally. Occasionally it can collect on the lowest point, which is the bottom of the bellowed hose near the front nearside wheel (need to take the radiator splash guard off). If oil is appearing externally, that's either the oil feed or return hose or a split turbo (unlikely) because you'd also be suffering power loss and all sorts. I think you should seek an opinion from one of the specialists who are regularly mentioned on the site. It's fairly common for the heads on the braided hoses to begin leaking - a quick tighten often resolves a leak. Without wishing to state the obvious, the most common cause of an oil leak on the 4.4 TDV8 is failed seals in or a warped oil cooler. The oil then makes it's way down the side of the block onto all sorts. I trust this has been investigated and ruled out or already done. 2015 Range Rover Autobiography 4.4 SDV8 Last edited by garyRR on 16th Aug 2022 10:48am. Edited 1 time in total |
| cass Member Since: 12 Oct 2011 Location: northumberland Posts: 797
Not sure how bad your leak is but mine has a receipt from a service before I bought it advising that a new turbo was needed due to an oil leak. It had 30odd tousand miles on it at the time. I've put nearly 100K miles on it and it still has the same leak.
| Kiss My Carbon Footprint Member Since: 19 Dec 2020 Location: Milton Keynes Posts: 147
Thanks to S60R and AJGalaxy2012.
| RBFFRR Member Since: 19 Feb 2022 Location: Blackburn Posts: 6
Resurrecting the 3 year old thread to ask the question...what was the outcome and did you get the turbos refurbished? Everything go ok?
RBFFRR,
Thanks Warwick, appreciate you replying. I'll give them a bell tomorrow.
| All times are GMT |
