![]() | Home > Maintenance & Mods (L322) > How to put the air vent silver trim back? |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 548 ![]() ![]() ![]() |
I've had a couple of these fall out as well. On both of mine, the tiny clip on the silver trim has broken on one side which meant it couldn't clip in place. Luckily I had some spares from a replacement air vent I bought ages ago for another job. Drives:
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1485 ![]() ![]() |
My clips aren't broken - it just doesn't seem to want to clip in. Does it need some force? 2015 Range Rover Autobiography 4.4 SDV8 |
Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 92 ![]() ![]() ![]() |
Apologies for hijacking, does anyone know if these clips are sold individually? I've totally lost one!
TJRL Member Since: 07 Sep 2019 Location: Reading Posts: 198 ![]() ![]() ![]() |
Me too, not the clip but the whole silver trim (inc. clips) in my case. Any info on where to get one much appreciated! 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD ![]() 1960 Land Rover SII SWB SW 2020 BMW R1250 RT LE 2021 Triton ST-125 (Monkey Bike) |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1024 ![]() ![]() |
The bay of E for the silver vents, if there not broken pull the whole front vent cover off and refit the little clips back in place. Not as fiddly as you think but you do need to remove the whole vent. |
How does it help removing the whole plastic trim when the silver bit is on the front of the vent? What am I missing here? 2015 Range Rover Autobiography 4.4 SDV8 |
Thanks Gsxr1250Dave, I have not seen just the silver trim bit, only complete front vent assemblies on the Bay. Is there a search term I should be using? 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD ![]() 1960 Land Rover SII SWB SW 2020 BMW R1250 RT LE 2021 Triton ST-125 (Monkey Bike) |
The complete vent is cheap enuff sometimes best just to swop them.out I had to replace 1 complete on my car |
gt40 Member Since: 30 Jan 2013 Location: Cape Town Posts: 31 ![]() ![]() ![]() |
These are available on Aliexpress from many different suppliers. This listing is for the Freelander 2 and one can simply remove the silver trim and fit it to your existing vehicle.
Many thanks gt40. |
This wasn't the right guidance to sort the problem. Over time and heat expansion and contraction, the plastic changes shape and will no longer retain the silver trim. Taking off sections of the dash will make no difference. The solution is to gentle apply some gorilla glue to the clips on the silver trim and re-insert. Problem solved. 2015 Range Rover Autobiography 4.4 SDV8 |
