Home > Maintenance & Mods (L322) > How to put the air vent silver trim back?
garyRR
Got in the car this morning and the silver trim on the air vent direction button has popped out onto the floor.
I cannot figure out how to get it back in - any tips? Are the clips known for going over time and super glue is my best friend?
I can see the little black tabs inside which the silver clips are presumably supposed to click onto but it keeps pushing out again.
 2015 Range Rover Autobiography 4.4 SDV8
Post #639925 17th Aug 2022 12:29pm
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
I've had a couple of these fall out as well. On both of mine, the tiny clip on the silver trim has broken on one side which meant it couldn't clip in place. Luckily I had some spares from a replacement air vent I bought ages ago for another job. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #639938 17th Aug 2022 2:30pm
garyRR
My clips aren't broken - it just doesn't seem to want to clip in. Does it need some force? 2015 Range Rover Autobiography 4.4 SDV8
Post #639951 17th Aug 2022 4:46pm
Rackers
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Apologies for hijacking, does anyone know if these clips are sold individually? I've totally lost one!
Thanks
Post #639961 17th Aug 2022 5:20pm
TJRL
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
Me too, not the clip but the whole silver trim (inc. clips) in my case.
Any info on where to get one much appreciated! 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD Sad
1960 Land Rover SII SWB SW
2020 BMW R1250 RT LE
2021 Triton ST-125 (Monkey Bike)
Post #640083 18th Aug 2022 4:34pm
Gsxr1250dave
The bay of E for the silver vents, if there not broken pull the whole front vent cover off and refit the little clips back in place. Not as fiddly as you think but you do need to remove the whole vent.
Post #640086 18th Aug 2022 4:40pm
garyRR
How does it help removing the whole plastic trim when the silver bit is on the front of the vent? What am I missing here? 2015 Range Rover Autobiography 4.4 SDV8
Post #640087 18th Aug 2022 4:43pm
TJRL
Thanks Gsxr1250Dave, I have not seen just the silver trim bit, only complete front vent assemblies on the Bay. Is there a search term I should be using? 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD Sad
Post #640089 18th Aug 2022 4:52pm
Gsxr1250dave
The complete vent is cheap enuff sometimes best just to swop them.out I had to replace 1 complete on my car
Post #640098 18th Aug 2022 8:10pm
gt40
South Africa 2011 Range Rover Vogue SE TDV8 Zambezi Silver
These are available on Aliexpress from many different suppliers. This listing is for the Freelander 2 and one can simply remove the silver trim and fit it to your existing vehicle.
https://www.aliexpress.com/item/1005001320...V7cCNHD8Tg
Post #640116 19th Aug 2022 2:27am
TJRL
Many thanks gt40. Thumbs Up 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD Sad
Post #640123 19th Aug 2022 8:03am
garyRR
This wasn't the right guidance to sort the problem.
Over time and heat expansion and contraction, the plastic changes shape and will no longer retain the silver trim. Taking off sections of the dash will make no difference.
The solution is to gentle apply some gorilla glue to the clips on the silver trim and re-insert. Problem solved. 2015 Range Rover Autobiography 4.4 SDV8
Post #641450 30th Aug 2022 5:31pm
