![]() | Home > My Range Rover > My 2011 Range Rover L322 4.4 TDV8 Vogue SE story |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2718 ![]() ![]() ![]() |
Fuel device pops back in with a long thin screwdriver dead easy |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8798 ![]() ![]() ![]() |
Thanks, I thought it might... |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
yellow tool should be in the boot, under the wheel cover, on right in a slot. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3329 ![]() ![]() ![]() |
Rear shocks ( genuine Bilstein) are £200+VAT each from Island 4x4 and more ( a lot more) from other places. Fitting them is pretty easy DIY as long as the lower bolt is not seized. Aux belts , idlers and tensioner replacement is a normal wear item on these engines but DIY is a bit tricky due to the amount stuff to remove to get to it. Check for oil leak down the back of the engine and oil in the coolant expansion tank as the other common fail is the oil cooler but you may be lucky and it's already been done. Rest should be no different to your SC. 2012 TDV8 Vogue (L322) |
John, I know where it should be but it is missing in action and has left the building... |
i think the later 'active' bilstein dampers are more like £450 a pop. - as i said, watch/read Sam's dilemma.... https://www.fullfatrr.com/forum/topic59154.html mine is fine, if i'm ever up your way, i drop in, and you can drive it. |
I was quoting for the late active dampers but as I said the prices vary quite a bit depending the supplier.
I certainly hope I don't have Sams issue, I feel for the guy.... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
Usual reason is the wiring at the top of the shocks - it's like all the wiring on these vehicles and has no sleeve on the last few inches so easily get severed with wear and insulator age. 2012 TDV8 Vogue (L322) |
I'm hoping it's that easy but I won't hold my breath....lol... Pete
..possibly, its the reason it was traded in. so, you might find, you got a car, with a problem, that you can sort, and the 'unknown' then becomes water under the bridge. |
Could be, either that or they were fed up taking an hour to fill it up with the missfuel device sprung...!!!
Looks like a speed camera detector....... 2012 TDV8 Vogue (L322) |
Wiring to all four shocks is fine, no chaffing anywhere...
