Home > Technical (L322) > Recommendations for engine swap garage 4.4 tdV8
Avityesboy
I need to get my engine replaced on my 2011 4.4 TDV8. Any reasonable (ish) garages that do a push in (lol) drive out service, car is currently in Oxfordshire but I can get it transported…
Post #640253 20th Aug 2022 7:53am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Take it to Glenrands.
But is it worth asking them to assess whether your existing engine is damaged beyond repair ? I think cam chain replacement is a 6 hour job
Post #640258 20th Aug 2022 8:37am
Avityesboy
Possibly, just think a second hand one with guarantee may be better, as it’s an interference engine the valves will be bent and all sorts of guess..
Post #640321 20th Aug 2022 6:50pm
JayGee
Any competent garage should be able to do the job so no need to go far from home but sourcing the donor engine will be the tricky part. I'd have thought it would be easier to replace the whole engine complete with ancillaries rather than swop them over from the old engine. 2012 TDV8 Vogue (L322)
Post #640327 20th Aug 2022 7:08pm
garyRR
I'd say only use one of the recommended garages on this site. They'll have done several engine out jobs on the 4.4 TDV8 before so, although the hourly rate might be a bit more, they'll probably get the job done quicker (and not miss off things like pipe clips etc!). Even 2 hours saved is a couple of hundred pounds, which leaves you no worse off anyway.
Glenrands are only just over an hour from Oxford. Can't remember the book time for an engine swap but I imagine it's in the 10 hour region so, c. £1,000-1,200 in labour inc VAT would be my rough guess, plus the engine obviously, plus oil and coolant and any other ancillaries.
My (bad) experience using a normal garage before was that a) they hadn't done that engine before and b) they charged a daily surcharge for 'ramp time' whilst the car was 'clogging up' the ramp (even though I pointed out that the vehicle still has 4 wheels and they'd likely roll it to the other end of the garage anyway!) Basically, normal garages don't want the job unless they can make a mint from it. So I recommend not even going there. 2015 Range Rover Autobiography 4.4 SDV8
Post #640333 20th Aug 2022 7:39pm
Avityesboy
Hopefully someone who can do it will see this post and PM me a decent ish quote…
Post #640334 20th Aug 2022 8:04pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
I don't know anyone that's tried this place but the reviews look good, maybe worth a try.
www.nwsmotorservices.com
Based in whitchurch Shropshire, not far from you.
Post #640352 21st Aug 2022 8:50am
JayGee
I wouldn't hold your breath......
Get on the phone on monday and get some quotes for supply and fit of an engine. I've seen a few places offering this on ebay with prices starting at around £7500 which is likley to be higher at a LR specialist.
Good luck Thumbs Up 2012 TDV8 Vogue (L322)
Post #640355 21st Aug 2022 9:00am
Avityesboy
Ouch…yeah maybe I’m hoping a bit too much, may have to resort to the spares or repair route getting rid…I just couldn’t justify going over 5k with repairs, even at that it’s owing me far too much tbh…
Post #640356 21st Aug 2022 9:16am
garyRR
Just on a quick search, tried this company?
https://www.ebay.co.uk/itm/173870185734?mk...media=COPY
The advert seems to signal all the right things to be looking for re re-engineering, checking tolerances, straightness of the crank, new pistons and gaskets etc.
I expect the price doesn't include labour. Explain to them the issues with your engine - they'll probably know what's salvageable if they need to rebuild yours vs buying a block in. 2015 Range Rover Autobiography 4.4 SDV8
Post #640359 21st Aug 2022 9:41am
mgrover
I've just seen this car being sold I think.
Was thinking about attempting the rebuild my self. Think they said cylinder 6 is dead but rest are fine? Do you have anymore info on it?
Cheers
Martin Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #640570 23rd Aug 2022 8:20am
garyRR
Are you posting on the wrong forum thread? 2015 Range Rover Autobiography 4.4 SDV8
Post #640571 23rd Aug 2022 8:24am
mgrover
Nah there's a car up on ebay fitting this exact description.
Looking at the users post history though it might be a different one.
But it's too much of a coincidence to be in the same place with the same issues
https://www.ebay.co.uk/itm/144688773520?mk...media=COPY Its actually a sport Sad
Post #640572 23rd Aug 2022 8:26am
garyRR
Still not sure what you're referring to.
Avityesboy's vehicle is non-running and iirc the timing chain has slipped off a sprocket potentially causing major damage, and the vehicle had 'Westminster' wheels.
Seems different to a vehicle described as having a 'misfire' and having black wheels. 2015 Range Rover Autobiography 4.4 SDV8
Post #640573 23rd Aug 2022 8:32am
mgrover
i guess we'll find out if its the same vehicle when Avityesboy replies Laughing
just seemed like too much of a coincidence very similar vehicles in Oxfordshire with engine issues. Its actually a sport Sad
Post #640576 23rd Aug 2022 8:43am
