![]() | Home > Technical (L322) > Recommendations for engine swap garage 4.4 tdV8 |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 840 ![]() ![]() |
Take it to Glenrands.
Avityesboy Member Since: 27 Apr 2022 Location: Kidderminster Posts: 24 ![]() ![]() |
Possibly, just think a second hand one with guarantee may be better, as it’s an interference engine the valves will be bent and all sorts of guess.. |
Any competent garage should be able to do the job so no need to go far from home but sourcing the donor engine will be the tricky part. I'd have thought it would be easier to replace the whole engine complete with ancillaries rather than swop them over from the old engine. 2012 TDV8 Vogue (L322) |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1485 ![]() ![]() |
I'd say only use one of the recommended garages on this site. They'll have done several engine out jobs on the 4.4 TDV8 before so, although the hourly rate might be a bit more, they'll probably get the job done quicker (and not miss off things like pipe clips etc!). Even 2 hours saved is a couple of hundred pounds, which leaves you no worse off anyway.
Hopefully someone who can do it will see this post and PM me a decent ish quote… |
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 785 ![]() ![]() ![]() |
I don't know anyone that's tried this place but the reviews look good, maybe worth a try.
I wouldn't hold your breath...... Get on the phone on monday and get some quotes for supply and fit of an engine. I've seen a few places offering this on ebay with prices starting at around £7500 which is likley to be higher at a LR specialist. Good luck ![]() |
Ouch…yeah maybe I’m hoping a bit too much, may have to resort to the spares or repair route getting rid…I just couldn’t justify going over 5k with repairs, even at that it’s owing me far too much tbh… |
Just on a quick search, tried this company?
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 422 ![]() ![]() ![]() |
I've just seen this car being sold I think.
Are you posting on the wrong forum thread? 2015 Range Rover Autobiography 4.4 SDV8 |
Nah there's a car up on ebay fitting this exact description.
Still not sure what you're referring to.
i guess we'll find out if its the same vehicle when Avityesboy replies |
