![]() | Home > Technical (L322) > I've joined the tailgate strap broken club. |
Chrali Member Since: 13 Apr 2017 Location: Norwich Posts: 122 ![]() ![]() ![]() |
Oh well jumped on the tailgate with my dog so we could cool down a bit before heading home, and the left hand side strap snapped (why is it always the left ?)
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8751 ![]() ![]() ![]() |
The pattern ones on eBay don't last long, and if both fail it can cost a few quid for boot damage...
Fair enough. Think the difference is the attachment for the damper on the other side. Now I look that's pretty crumbly as well. I'm not sure the rubber cover did anything more than trapping the water in there.😅
Soak it in penetrating fluid for a few days and then try with a set of molegrips, they aren't usually very tight... |
QuebecTango Member Since: 06 Jan 2019 Location: Brighton Posts: 56 ![]() ![]() ![]() |
Mine broke as well the difference is the damper attachment on the o/s, got them from Advanced Factors seems ok. |
The drain holes are clear, so i can't explain it. Perhaps it was a souvenir from the Titanic? |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 710 ![]() ![]() ![]() |
I bought genuine straps from the forum sponsor Duckworths.
Yup will do.
I got no reply back from Duckworths, so ordered the parts from Advanced Factors. Lubricated them thoroughly with spray on grease and fitted the passenger side ok. The drivers side was a |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 312 ![]() ![]() ![]() |
Mine were both broken when I bought the car 2 weeks ago (crikey, has it only been 2 weeks?🤣). Bought a couple of third party ones from Amazon (Rear Tailgate Boot Strap Cable... https://www.amazon.co.uk/dp/B08PBL66WK?ref=ppx_pop_mob_ap_share)
I was tempted to get the Ebay/Amazon ones, but as we do put a lot of weight on it I didn't want to be penny wide pound foolish. I guess the nut was swollen due to corrosion, but the biggest problem was everything being corroded so the straps didn't pivot.
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1240 ![]() ![]() ![]() |
The OEM straps on my 2010 were seriously rusty under the rubbers so replaced with aftermarket and check on them on a regular basis.
