Home > Maintenance & Mods (L322) > Engine chirp when cold |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 632 |
I have a chirp from the engine bay when cold, and usually disappears when warned up.
21st Aug 2022 1:57pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Just been reading up on this, new to me, engine.
21st Aug 2022 2:41pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4225 |
I had same. The top left pulley had gone badly. Its the one at extreme top left looking at engine 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
21st Aug 2022 2:48pm |
https://www.advancedfactors.co.uk/auxiliar...1791-c.asp
21st Aug 2022 2:50pm |
Rob, he said he changed all the pulleys for genuine ones last year.... Pete
21st Aug 2022 2:57pm |
That describes mine all too well.
21st Aug 2022 5:41pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2652 |
AFAIK fan and shroud have to come out - big job 2012 TDV8 Vogue (L322) |
21st Aug 2022 5:45pm |
21st Aug 2022 5:52pm |
Spray some water on the belt and if the noise goes away it's the belt and not an imminent problem. If the noise persists then it could be a bearing which you need to sort ASAP as it can fail and it will take out the belt. 2012 TDV8 Vogue (L322) |
21st Aug 2022 6:09pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 304 |
mine (2012 4.4TDV8) chirps when cold - most years it goes away in spring but this year it still happens a bit, especially on cooler days. I have had the belt tensioner mod done too. 2012 L322 4.4 TDV8 AB low mileage - a peach
24th Aug 2022 12:18am |
Cheers JayGee. I’ll give that a go and will prioritise accordingly.
24th Aug 2022 6:42am |
I wasn't aware of a 'mod' either and thought it was just replace when it's worn or belt is running off the edge. 2012 TDV8 Vogue (L322) |
24th Aug 2022 8:37am |
LR022810 is the idler pulley tensioner upgrade.
24th Aug 2022 10:43pm |
Interesting…
25th Aug 2022 7:44am |
